Up for grabs is my beloved GODZILLA
Genuine reason for sale, having money trouble...
1993 Series 2 GTR in silver imported less than a year ago
120,XXXkms
Just had full 100K service (including GATES timing belt & water pump & all fluids) $1400
Brand new alloy radiator
new 550cc SARD injectors
Bosh fuel pump
Power FC with hand controller
N1 Turbos
N1 headlights
N1 body kit
Nismo clutch
3" KAKIMOTO exhaust
Greddy pod filters with aftermarket piping
Z32 Air flow meters
Recaro drivers seat
NARDI steering wheel with quick release (very nice wheel)
New alarm & stereo with 25GB HDD
New legal window tint
lots of money spent, everything is perfect mechanicaly and interior. front bar is bit faded and there is a stone chip in rear gaurd, other than that paint is pretty good too.
Dyno Tuned at Intune by Ben
241AWKW @ 16PSI with very safe tune still running alittle to rich. Can race all day without any trouble.
Not that I've ever had it at a track day.
more pics to come..
  • Replies 48
120,XXXkms
Bosh fuel pump
N1 Turbos
N1 headlights
N1 body kit
Nismo clutch
3" KAKIMOTO exhaust
G
Z32 Air flow meters
Recaro drivers seat
more pics to come..
hi mate
where is the car located and can you post up some more pictures.
thanks
120,XXXkms
Brand new Cusco alloy radiator
Bosh fuel pump
HKS timer
N1 Turbos
N1 oil pump
N1 headlights
N1 body kit
Nismo clutch
3" KAKIMOTO exhaust
Z32 Air flow meters
Recaro drivers seat
New handbrake and gearstick boots
lots of money spent, everything is perfect mechanicaly and interior. front bar is bit faded, theres a scratch on the left side and there is a stone chip in rear gaurd, other than that paint is pretty good too.
241AWKW @ 16PSI with very safe tune still running alittle rich. Could lean out and wind up the boost abit more for more power.
I've never had it at a track day or pulled the 4WD fuse out for drifting or burnouts. Car always warmed up and driven maturely. Car was imported in 08 & has never been treated badly. Nothing more to do mechanicaly, just needs a re-spray and R34 GTR wheels :-)
is that ur attemp to strip back the paint from the plenum or is this how it was?
good mods and good price, now to just sell my car !!
Hey budy, nah if anything I would paint it.. Its the way it came from Japan, I think it had a aftermarket plenum on it in Japan and someone put a stock one back on it for compliance and rego. Same with the front bar and boot spoiler wich are both faded and chiped even though the rest of the paint is pretty good.. Got a quote for the bar, boot spoiler respray & stone chip repare at J-racing for $1000.
Just realized i forgot to take a pic of the dyno printout, i'll get onto that asap..
Negotiable at all on price? canberra person, may be interested in it. whats your mobile? noticed this was complied by envy imports, had any issues with it since you've bought it?
A little negotiable :-)
Only trouble Ive ever had was when it had its major service, when trojan tried to fit new radiator hoses the old radiator plastic intake pipe crumbled so now it has a big thick alloy Cusco radiator.
 Share
    • normally i don't like to get involed with these kinds of self promotions stuff, but good on you for living your dream man.
    • Remember our cars are 30+ years old so expect the rubber bits to leak. I'd go around your engine bay with a can of "start ya bastard" or similar and look for leaks. FYI I got my car 10+ years ago with the standard boost restrictor in place, I removed it when I got it and the car never had any issues since (besices a leaking manifold gasket). tl;dr- Look for leaks before proceeding.
    • That SSR is actually the same (or similar) as the Jaycar 100AMP SSR (which I use). They suggest the resistor to stop the SSR turning on when the ECU turns off (I believe). I personally don't use the resistor as I use the 5V output from the ECU to supply power to the SSR. I do however run a flyback diode, the old Haltech documentation was wrong too and didn't specify the fly back, I mentioned it to a few of their staff and they eventually added it in.
    • I did manage to do this without removing the engine or front cross member, but I had the advantage that the exhaust manifold was removed. I am not setup to support the engine from the top or remove it. 1. Loosen the engine mount nuts so they only have a nut of thread. If it is a manual, I think you have to remove the gearbox to engine support brackets. 2. Jack up the engine off the bottom idler mount. Jack it up till the end of the slot and nut on the mount. You need this clearance to get the pan out at the rear of the engine. 3.Break the sealant seal to sump. I found a oil pan separator tool helpful to get it started. 4. The oil pick up can be removed with the gap available.  5. The oil pan can be removed now. 6. Before assembling, do not apply sealant to the oil pick up area as your hand will rub it all off but apply to the other three and a bit sides. 7. It is a two man job to put the oil pan back, with the sealant, as you do not want it to touch anything and rub off. 8. With one person supporting the oil pan the other can fit the oil pickup 9. Apply the remaining sealant. This would be more difficult with the manifold or turbo in place, but I think it could be done. As you can see my sealant is a bit ugly, but good enough to seal. 10. Lift the sump up to the engine and bolt it on. We found it was easier to use two long guide bolts at each end to get it nice and aligned without touching.
    • I find building an exhaust a really satisfying job! Looks nice!   Did you consider using an oval pipe to get the same cross sectional area but keep it above the chassis rail?
