Hi All ,
Long time reader, just joined.
Just bought me a 350 GT-8. Loving every bit of it. :D Nice to know we've got a community dedicated to these magnificent cars.
Anyhow, i was thinking of doing an upgrade to the existing bose stereo. Nothing wrong with it, but would be nice if i can play mp3s
and such.
I was thinking of Pioneer AVIC-F800BT. That thing looks sweet!
Can someone point me to the right direction of getting it installed professionally in Perth? Would be nice if they've worked on the car before and knows exactly what they're doing and which fascia plate to get.
@ Chris : You seem to know a lot about the stereo upgrades for v35s. Any chance you might know someone down here?
Cheers
https://www.sau.com.au/forums/topic/273001-v35-stereo-upgrade/
OK, called Brian, got a quote for $2000. This includes :
- Head Unit : JVC AVX810
- Amp : Kenwood 600 Watts
- Silver fascia Plate + dual zone AC controller
- Swix Steering wheel control adapter
- Labour
I thought it was a reasonable price since it seems like he knows his way around the V35s. So i went ahead with it. Installed it today, took him 10 hours.
While it sounds and looks good, to be honest, i miss the original look . The AC controller looks a bit crappy with grey rubber buttons. It' s missing the bracket around it to make it flush, cause it needs to be trimmed a bit so the unit can open. Here's some pic of it. Whadya guys think?
that is a very cheap quote for the fascia / buttons. he must have some aftermarket ones there, because the original nissan parts for the v35 cost somewhere in the vicinity of $1000 delivered.
(oh i re-read your post and to point out yes, the buttons are not supposed to be rubber, it does kinda look tacky! devalue the look somewhat..... you can buy the orginal buttons from japanparts.com)
Edited by BLISTC
Tell me about it! It's got an annoying feel to it when u push the buttons. hey here's an idea.. How bout instead of getting it from japan parts, can i just swap the buttons from my original fascia?
that looks like a later car. the panel and correct contrls are roughly $1k. last set I sold was about that and those went to a customer in canberra.
wht you have is a metra kit. are the controls slow to respond?
nope. its all one big board behind that panel. its OEM buttons (IE new controller) or nix.
No, not really. It just lacks the haptic feel of the original buttons. Man i should've done my home work first :happy:
But actually, now that i know the original can cost $1K, i don't think i could afford it anyway!
Overrall i'm 80 % Happy with it. The Lcd takes my attention away from the buttons :ninja:
In the future, say if i wanna sell the car, is it possible to install the original dash in with the bose and all?
If it's not, would it sell here? :)
did u use back your old tv from your v35 or u got yourself a new system ?
I purchased the car with the tv and GPS already installed. It looks like the GPS has been converted to Australian maps, the tv i think is like a piggyback system that has plugged in to the original unit coz it has its own remote receiver and instructions for using the tv... but still goes thru the main oem console because if u disconnect the battery u have to set up the tv again thru the japanese menu buttons... I'll ask them about it this wkend as they're swapping the DVD unit as the first one they installed went dodgy after a couple of weeks (wouldn't read the dvd and had troubles ejecting and inserting the DVD)...
Ok, been testing the audio for a couple of days. Sounds okay, but the woofer sounds like it's gonna rip anytime soon. Maybe because the amp is 600 watts.
I was thinking of changing only the sub to something that can take the amps power a bit better. The thing is, my boot space is precious and i don't wanna put a bass tube or anything like that.
IIRC, the stock sub size is 10". So can i just get any sub that size and replace the existing one?
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
