This is what i had intended to do to my RB20...but with an OS holiday next year and work etc, i cant really see myslef doing it.
Bore the engine to use 81 or 82 mm forged pistons, balance and prep std rods and crank, serviced head, with some basic match porting and cleaning up, GTR oil pump, 8.7:1 compression, 264 cams and new valve springs. HPC coated valve faces, exhaust valves stems and combustion chambers.
If i could score an RB26 crank and rods off a friend for the right price i would also use those as the additional cost for machining was only another $200.
So for about $4500-5000 i would be able to run 1.5bar from my TD06 and use a 8,500 rev limit. I would expect a damn strong 250-260rwkws with full boost coming on strong at around 3,600-3800rpm. Then as a T67 bolts to my current manifold and dump,
300rwkws would only be a turbo change away less the sale price of my TD06.
  • Replies 48
Ok guys, this has opened a real can of worms. So lets get back to the main topic hey. Im not too worried about gearing and speeds of silvias and skylines etc. Basicly, for the show, the next project car is the skyline, and our aim is to make the toughest R32 skyline, using the RB20 motor. The RB25 and RB26 are all good and stuff, but how many kickarse RB20's are there? None that i know of. So, basicly, all i really want to know, is what turbo setup should i use to gain that power figure. It really doesnt matter if its for track or drag or street, i really dont think that is an issue. Basicly the car will be showed around aus, so we can eliminate that issue. The gearing is all well and good, but im not worried about what power it will be making at what revs and gears, all interesting though. It is a decision between doing a single turbo setup, or a sequential turbo setup. The rev ranges are general ideas on where we want boost to be at. I would prefer them to be lower and flow right through.
As this is a sponsored car, anything is possible.
This is a rough idea on what will be done to the motor.
New forged cams
Metal Headgasket
port/polish
forged pistons
forged crank
Block shot peened for strength.
Blue printed
Larger sump with baffels
12a injectors
Larger fuel pump
Computer
New turbo with external waste gates. Either single or twin setup
All intake piping
Largish intercooler( From boonet to bottom of gtr lip, and spotlight to spotlight. IS a biggen)
Larger throttle body
Larger plenum
Tuned intake manifold piping
Tuned exhaust manifold piping
3.5inch Twin dump
3.5-4inch exhuast( but retaining quietness, well, close... maybe not..?!)
New 6 speed box(possibly s15 box. Have parts strengthened for the job)
Double or triple brass button( has single now, is bitch to drive with)
Strengthened tailshaft
Diff, not so sure. Have been told will handle power. Well, everything bar the box will handle the power we have been told. But doing all the work to make it a bulletproof setup. What want the power, and the reliabilty. All persons involved say its a reasonable goal, and is a piece of cake.
AS i said before, with sponsorship, anything can be done.
Different story here - before it was 400rwhp with good boost under 4k
agree with rbs13 go rb25 g.box - tough as nails
also, I would suggest something like an OS Giken twin plate - nice take up and will easily hold 400rwhp.
Turbo - Something like a HKS 3037, 3040 or garrett GT30 or GT35R, also as suggested T67 (but will be a bit more laggy).
Something like a 3037S 56T with a 0.73 turbine AR, around 1.5-1.7bar bar(use a 0.87housing if you dont want to have to use that much boost pressure, but from the sounds of your build up the engine wont have a problem) and you will have 400, or if you think you may want to try and get a few more ponies out for dyno comps, try a HKS 3040, but you will probably find it a bit more laggy, maybe another 500+rpm.
Some suggestions anyways.
Well since it seems like you have sponsorship and ppl building the engine, they will best be able to tell you what suits your needs.
Thats two votes.
Thanks for the replys guys, just wanted some feedback from the people who know the skylines the best. We dont want to be wasting time with people thinking this should do it etc etc.. What do you guys think for a twin sequential setup?
agree with roy there.. but a twin t25's should work.... and boost up.. that would cut costs down.. as the turbos are cheap but the manifolds mite even up the cost compared to a big single.. if u want a drag car.. go auto with trans brake and a stally.. use the nos to bring the turbo on.. and you WILL run VERY quick times.. no fun for the street tho.. just suggesting some thigns.
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
