Brand New R33 Gtr Gear Box + Many Parts 4 Sale
r33 ross
 Share
This box was fitted to my car the day before i crashed it.
Done less than 80 kms.
These sell for $3500 at Just Jap Auto imports.
Its a series 3 box and will fit all R33 gtr not sure about 32.
Will include a brand new nismo g/box mount worth $300 as well.
Also comes with the transfer case.
Why reco your box for $1500-$2000 when you can buy new for this price with transfer case and nismo mount.
Will sell for $3000 ono
Also have the original box without the transfer case.
It needs a new front cluster bearing otherwise is in excellent working condition.
It would get a neutral every ten or so changes into fifth.
Sell for $400
PWR front mount i.c 600 x 300 x 75 $300
Rare Mines 320 km speedo (black face) v-spec $500
Still have all the drivetrain v-spec diff, pumps etc
Also have the RB26 from the same car. It was putting out 280+ awkw with 2860 garretts on 14 psi
has 650 sards
type b poncams
jjr coils
tomei cam gears
gates belt
n1 water pump
turbos have been removed but can supply R 34 turbos in good condition if needed.
comp tests welcome, good strong engine.
$5000 no offers
Many other parts available
Located in Brisbane
Inspections welcome
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
