Hey,
I have an A31 here that i am in the process of getting back on the road, it has had the hicas removed, but half of the power steering stuff is still not connected.
I have this picture of my rack, i know 2 fittings go to either side of the rack but i need to know where the other 3 fittings should go to (with the hicas removed).
Which one is pressure feed?, return?, and should the remaining fitting be blocked off?
Thanks,
-matt
https://www.sau.com.au/forums/topic/273056-steering-rack-in-a31/
If it is a hicas rack it should have a feed and return to the pump/resevoir, and the 2 lines to each side of the rack (just like a regular front steering rack).
Then it should have 4 holes for the hicas. These holes are completely seperated from the hydraulics of the front rack. Their only function is as a connection block to join the hicas lines from the rear of the car to the hicas lines in the engine bay.
If you have no intention of refitting hicas then you can leave those 4 holes unplugged.
If you still have a hicas pump and reservoir just loop it straight from the pump to the reservoir, that way you don't have to worry about keeping the lines under the car and looping it around at the back (where the rear hicas rack was).
Alright well I double checked the rack and its only got a total of 5 fittings.
Im guessing its non hi-cas?
Would someone be able to tell me which one is feed, and are the remaining 2 both returns to the reservoir?
The rack also has a silver sticker saying "Drive PRO" but nothing else. Has anyone heard of this?
-matt
I just checked my rack, it only has 4 fittings there (and another 4 on the rear for the hicas lines).
The 2 on the left go to either side of the rack, the bottom right is supply from the pump, and the one above that is return to the reservoir.
I don't know about that top one though as my rack doesn't have that.
  • 4 weeks later...
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
