Nah the clutch was in good condition, was not too old and didn't go out in the usual way. It was either air in the fluid or the clutch fork & pivot were not aligned properly causing the crunch, and ultimately caused the pivot to fail.
600hp eh... yeah I imagine you would move through clutches fairly regularly. Better than gearboxes or driveshafts.
Cheers Paul, mine may not be the same as your issue as I don't get any crunching just hard to get in gear, like the original poster. I'm gonna PM him to see what he found in the end. It's not all gears, well all a bit stiff but esp 1st, 2nd and 3rd.
DS what symtoms are you getting, crunching, hard to get in gear or both?
M
Sorry I mean't that the pedal was a little crunchy, almost like you could feel something was wrong with the slave / fork.
Was hard to get in to first, second and reverse as the clutch was not disengaging properly.
Okay Cheers Paul, did you get a drop in clutch fluid from the master reservoir? I've checked mine daily and it hasn't moved, still full so not sure if I have a leak although there could be air in the system, it does look a little dirty as well. Would you suggest a clutch bleed and refill before anything else? Fingers crossed this will cure it, what about adjusting the biting point out a little?
And original poster let us know what it was! :-)
M
  • 2 months later...
Hey guys.
I've got a 1990 GT-R and have a similar problem. Unless I change at lowish revs (around 3000rpm or lower), or really baby the gear change, I get grinding going from 3rd to 4th gear. Every other gear combo seems ok, although I haven't driven any other GT-R's so can't compare the feeling. Seems odd to have a prob going 3-4, since it's probably not an overly tortured combo - 1-2 for example would be more stressed I would think.
If anyone can shed some light I would be most appreciative :thumbsup:
  • 3 weeks later...
Hey guys.
If anyone can shed some light I would be most appreciative :banana:
Geez, I have the same issues but also I have trouble engaging in general. Going to get the whole clutch bled and tested asap. You should do the same as its the cheapest and seemingly the most obvious thing to check out before digging into worn syncros. Time to get under there and grab that nipple, haha.
And omega 36, how hard was it to source and replace a new clutch diaphram (+ total cost)?
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
