Hey peoples, clearing out my shed, so here it goes. I'm in Wodonga Vic. so postage can be done.
Garrett T04S $490: 0.84 AR, 550HP. I was running this turbo on my RB25det before it was removed.
This was removed for upgrade, worked perfect when removed.P1010633.jpgP1010635.jpgP1010639.jpgP1010643.jpg
HKS Computers $290 for the lot: * Comes with HKS mould for mounting in glove box. (was in my R33 gtst s1 glove box, unsure if it will fit other boxes without modification), looks great also room for two more guages.
-F-CON V : Fuel and Ignition Timing HKS Computer
-Vein Pressure Converter
-PFC F-CON Graphic Control Computer
These were removed for upgrade, worked perfect when removed.
GReddy adapter plate $70: For sale is a GReddy adapter plate used to mount up a GReddy (genuine or Ebay) plenum to the stock throttle body and piping.P1020031.jpg
Alpine Head Unit CVA-1000 $350: Single din, flip out screen. Comes with Alpine T.V. tuner, T.V. arials, Alpine graphic equalizer. Ai-Net, Remote controls (head unit and tv tuner) Great head unit.23211007.jpgDSC00314.jpg
Joytech X-Box power inverter $50: I tried to run a x-box off a run of the mill inverter with no luck. This inverter is desinged for it. Works great. Practicaly brand new.DSC00312.jpgDSC00313.jpg
R33 gtst s1 steering wheel $40: as is.
R33 gtst s1 Injectors (x6) $50: These were removed at 110,000kM for upgrade, worked perfect when removed.P1020045.jpg
R33 gtst s1 Blow Off Valve $10: This was removed at 110,000kM for upgrade, worked perfect when removed.P1020046.jpg
R33 gtst s1 HICAS $30: HICAS sytem removed from car at 120,000kM.DSC00316.jpg
R33 gtst s1 Boost Accuator $15: as is.
R33 gtst s1 Water Pump $30: This was removed at 110,000kM for upgrade, worked perfect when removed.DSC00319.jpgDSC00320.jpg
R33 gtst s1 Front and Rear Seats, Door trims $290: Removed from my R33 gtst s1 2 door, at 120,00kM, in great condition.P1020038.jpgP1020040.jpgP1020041.jpgP1020043.jpg
Oil Catch Can $15: As is. http://i97.photobucket.com/albums/l213/Bre...33/DSC00321.jpg
R33 gtst s1 Clutch Fan $20: This was removed at 110,000kM for upgrade, worked perfect when removed.
http://i97.photobucket.com/albums/l213/Bre...33/DSC00317.jpg
R33 gtst s1 Air Flow Meter $50: As is. Was working fine when removed. Only removed for upgrade.
http://i97.photobucket.com/albums/l213/Bre...33/P1020033.jpg
Also I will be selling my Cooling Pro (justjap.com) intercooler very shortly as I have a new one ordered, send me a PM if you're interested, it is in great condition and hasn't done many kilometres.
Thanks.
BrendanR33.
Turbo come with actuator or any lines?
I do have lines somewhere, I recently moved house and can't locate them at the moment, will have a better look tomorrow.
No actuator, sorry.
I also have a stock R33 gtst clutch. Good condition, $50.
Cheers.
Air flow meter = Sold Pending Payment
Steering wheel = Sold Pending Payment
Blow Off Valve = Sold Pending Payment
Clutch Fan = Sold Pending Payment
dnggskyline - PM sent
tommygr34 - PM sent
Also Note on turbo: I have lines and top of dump pipe (inserts into turbo). These will come with the turbo.
Catch Can = Sold pending payment.
Injectors = Sold pending payment.
Clutch Fan = Sold
Also a photo of what will come with the turbo.
Turbo is rated to 550HP.
  • 3 weeks later...
Clutch Fan = Sold
how much shipping to perth wa for the turbo....
Alpine gear = SOLD
Sorry about the late replies, I have just got back from holidays.
All P.M.'s replied to.
Shahkaka: I will P.M. you a price asap.
John26: The computers were running my RB25DET, whether or not they will be compatible to anything else I'm not sure maybe google holds the answer?
All prices are now negotiable.
hey there after window switch, bonnet release mech ( pull with spring), den for centre console, , might be interested in entire dash insert at good price. pm asap. nick 0404099310
What? None of this is advertised here. Please note, you do not have a P.M. nor will I be calling you.
