Hey peoples, clearing out my shed, so here it goes. I'm in Wodonga Vic. so postage can be done.
Garrett T04S $490: 0.84 AR, 550HP. I was running this turbo on my RB25det before it was removed.
This was removed for upgrade, worked perfect when removed.P1010633.jpgP1010635.jpgP1010639.jpgP1010643.jpg
HKS Computers $290 for the lot: * Comes with HKS mould for mounting in glove box. (was in my R33 gtst s1 glove box, unsure if it will fit other boxes without modification), looks great also room for two more guages.
-F-CON V : Fuel and Ignition Timing HKS Computer
-Vein Pressure Converter
-PFC F-CON Graphic Control Computer
These were removed for upgrade, worked perfect when removed.
GReddy adapter plate $70: For sale is a GReddy adapter plate used to mount up a GReddy (genuine or Ebay) plenum to the stock throttle body and piping.P1020031.jpg
Alpine Head Unit CVA-1000 $350: Single din, flip out screen. Comes with Alpine T.V. tuner, T.V. arials, Alpine graphic equalizer. Ai-Net, Remote controls (head unit and tv tuner) Great head unit.23211007.jpgDSC00314.jpg
Joytech X-Box power inverter $50: I tried to run a x-box off a run of the mill inverter with no luck. This inverter is desinged for it. Works great. Practicaly brand new.DSC00312.jpgDSC00313.jpg
R33 gtst s1 steering wheel $40: as is.
R33 gtst s1 Injectors (x6) $50: These were removed at 110,000kM for upgrade, worked perfect when removed.P1020045.jpg
R33 gtst s1 Blow Off Valve $10: This was removed at 110,000kM for upgrade, worked perfect when removed.P1020046.jpg
R33 gtst s1 HICAS $30: HICAS sytem removed from car at 120,000kM.DSC00316.jpg
R33 gtst s1 Boost Accuator $15: as is.
R33 gtst s1 Water Pump $30: This was removed at 110,000kM for upgrade, worked perfect when removed.DSC00319.jpgDSC00320.jpg
R33 gtst s1 Front and Rear Seats, Door trims $290: Removed from my R33 gtst s1 2 door, at 120,00kM, in great condition.P1020038.jpgP1020040.jpgP1020041.jpgP1020043.jpg
Oil Catch Can $15: As is. http://i97.photobucket.com/albums/l213/Bre...33/DSC00321.jpg
R33 gtst s1 Clutch Fan $20: This was removed at 110,000kM for upgrade, worked perfect when removed.
http://i97.photobucket.com/albums/l213/Bre...33/DSC00317.jpg
R33 gtst s1 Air Flow Meter $50: As is. Was working fine when removed. Only removed for upgrade.
http://i97.photobucket.com/albums/l213/Bre...33/P1020033.jpg
Also I will be selling my Cooling Pro (justjap.com) intercooler very shortly as I have a new one ordered, send me a PM if you're interested, it is in great condition and hasn't done many kilometres.
Thanks.
BrendanR33.
Turbo come with actuator or any lines?
I do have lines somewhere, I recently moved house and can't locate them at the moment, will have a better look tomorrow.
No actuator, sorry.
I also have a stock R33 gtst clutch. Good condition, $50.
Cheers.
Air flow meter = Sold Pending Payment
Steering wheel = Sold Pending Payment
Blow Off Valve = Sold Pending Payment
Clutch Fan = Sold Pending Payment
dnggskyline - PM sent
tommygr34 - PM sent
Also Note on turbo: I have lines and top of dump pipe (inserts into turbo). These will come with the turbo.
Catch Can = Sold pending payment.
Injectors = Sold pending payment.
Clutch Fan = Sold
Also a photo of what will come with the turbo.
Turbo is rated to 550HP.
  • 3 weeks later...
Clutch Fan = Sold
how much shipping to perth wa for the turbo....
Alpine gear = SOLD
Sorry about the late replies, I have just got back from holidays.
All P.M.'s replied to.
Shahkaka: I will P.M. you a price asap.
John26: The computers were running my RB25DET, whether or not they will be compatible to anything else I'm not sure maybe google holds the answer?
All prices are now negotiable.
hey there after window switch, bonnet release mech ( pull with spring), den for centre console, , might be interested in entire dash insert at good price. pm asap. nick 0404099310
What? None of this is advertised here. Please note, you do not have a P.M. nor will I be calling you.
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
