Hi all.
I was just after some advice on what people have used and what brand have proven to be good quality.
I'm after some adjustable camber arms and caster rods for the front of my GTSt. It is used for track and drift.
I currently have whiteline bushes and they have been good but now I want more adjustment.
What brands are easy to get in aus and good value for money?
This thread had a bit of info. Click
thanks
Russ
https://www.sau.com.au/forums/topic/273142-r32-gtst-adj-suspension-bits/
When I bought my 32 it came with adjustable castor rods, i'm not sure which ones they are but the rods themselves are much thicker than most of the ones pictured, probably similar to the tune agent ones but different design, no worries with them whatsoever. There's a group buy going on at the moment for pivoting upper front camber arms think there $400 a pair, i've been looking around at the different options and this type seem to be the best option, I really want to get a pair for both my cars but don't have the cash at the moment :P
whiteline do some adjustable arms with urethane bushing, reliable design, somewhat outdated (as far as clearance for larger coilovers go at the rear), and u have the aussie support.
as far as rose joint stuff, cusco and ikeya formula are ur best bet for quality.
theres also a bloke here in SA looking to start making proper quality stuff as an alternative to the junk which makes up the majority of the market atm.
Hey Russell, I got my cusco castor rods and cusco rear camber arms on a trip to Adelaide from Japanese Import Spares. I had just planed on buying s/h items but after inspecting all the s/h stock they had I was a bit apprehensive, and I was kind of in the mind set of do it once do it right, so I ended up getting new ones. Although when I got my arms they were a lot cheaper then, than the price they have listed now. But I guess if you’re ever over that way they do a better price for cash.
http://www.japaneseimportspares.com.au/par...riesalignment/2
Russ what are your current alignment specs, and what are you hoping to achieve? The Noltec front upper arms would be the way to go, but again they are pretty pricey and quite hard to get. I ended up going with the 33 lca's, many people would argue that that is the wrong way to go about it, but i can only give positive feed back, for the price they are a good cheap upgrade. They gave me -2.5 degrees of camber up front. I haven't heard a lot about the Kazama stuff but there seems to be a few people running them, hopefully they can provide some feed back. My guess is that they would be better quality than some of the other brands getting around but not quite as good as the high end Japanese stuff.
Have you checked the bump steer? Ackerman?
Cheers
Gary
Whaaa? SK... Do i see a ghost ? :P
I looked at Kazama gear and frankly, i would stick with the Cusco castor rods. If you cant get the Noltec upper arms then i would bust John and UAS in Sydney in the chops and see if he has his upper arms production ready yet. They seemed to be a good lcoally engineered product that are being R&D in the wraith of a car of his.
I think i only paid about $350 for my Cusco castor rods
Cheers
Gary
Nope. But after your group buy fell through i had to look at alternataves. The 33 lca's were nearly three quarters cheaper than any of the upper arms available. Seeing as not many people were running them i thought i would give it a shot, and seat of the pants review, they provide more gains than drawbacks. I still have my 32 lca's and if i ever do find some decent front uppers, such as the noltecs, i'll put the 32 lca's back on.
Brake fetish is over. I am back to my wanting a 9,000rpm 300rwkw RB20 :)
yes please.
i think i might be throwing u a PM in the future, was originally gonna be like every other f**ker out there and put a RB30 in, but starting to think a build RB20 is the way to go.
yes please.
Yeah man. RB20's are sweet. Mine gets 1.5-1.6 Bar all the time and it loves it!
What am I hoping to achieve? Well I mainly want adjustability so I can try stuff to see if it works etc. I have camber and castor bushes (whiteline) that give some adjustment but I want to tinker and fiddle with stuff and learn while I'm at it. I do need more camber though so that's the main thing.
Was thinking about 33 lca's but yeah... Heard it's not the best way to go. I don't have buckets of cash so if I buy stuff it will be one at a time as I continue to develop the car.
apparently 33 LCA's will get u -1 degree either side. they are next on my list. but i think ill hold out til this guy i was talking about has developed a few suspension items. he is using all the best quality stuff, and all machining is done in australia. atm its just a backyard operation, but with the amount of research he has done u can be guaranteed the products are going to be top notch and even better in some instances than some of the top products. the only difference is he wont have the same margin as companies like cusco etc
Any idea when this will be?
no idea sorry, he's working on some stuff atm, i think he's still working with local machiners to get the price right, the funny part is his prices will probably still be competitive and in a lot of instances cheaper than the brands which just rebadge generic stuff from china/taiwan, its not so hard to understand however when u look at the incredible markup placed on the generic stuff.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
