huh? stop smoking cheap crack!
If you are bothered to do that...
Then why not do something extremely different.. 11L cummins! It will run smoother, make less impact to the world and it WILL make big power and huge torque!
Sound totally stupid now doesn't it!
  • Replies 59
Posted Images
LOL
The Australian hillclimp championship was won be a Buick V6 powered car (and not the first time either) not to mention the odd circuit lap record - I don't see them jumping to a Cummins anytime soon.
....and to think he pulled a Cosworth V8 out of the car too to replace it with the V6 because he wanted more torque!
Edited by juggernaut1
LOL
i though peter won it again in his super charged vw open wheeler?
Well i personally am not a fan of Bastard engine swaps., ie engine from a different manufacturer
But to go a little against the grain the V6 engine by Buick is quite an animal. For all those slinging crap at it check this one http://www.youtube.com/watch?v=djN94DHkAsA
Edited by GTR-32U
If we are talking CRAAAAZEEEH engine swaps its simple as far as im concerned.
LS2 + stroker kit + underbonnet screw supercharger with sandwiched water to air cooler in the intake manifold.
- instant torque
- power
- response
- revs its tits off
- would destroy a dyno
- can be driven every day
- will be reliable.
Or a dodge viper V10, your choice. Its shorter than an RB... Saw one fitted into a HQ sedan at the tassie hot rod nationals.
Gary West came out of retirement pulled the car out of the garage and won the title with the normally aspirated Buick V6 powered open wheeler....again.
Pretty sure this car also holds the outright lap record at Barbagello too.
- instant torque
- power
- response
- revs its tits off
- will be reliable.
Problem with the positive displacement supercharger on the LS is that they have too much low down torque and sacrifice top end. Mate has one on a Monaro and now he's putting traction control on it. Brother has a twin turbo LS2 and makes more power everywhere from 3200rpm when it hits full boost and is much more tractable than my mates supercharged Monaro.
Depends if you want to do skids or have a fast car I guess.
LOL
so the fact that the buick motor was in a car that probably only weighs 700kg has nothing to do with it...... also nothing to do with the fact that it is a 4.2L v6 buick motorsport engine and has no parts in common with the holden v6...... also the v8 it replaced was only 3.0L.
that is like saying the holden v6 is better then the v8's used in the v8 supercars because the lap record of a formula holden lap record is about 8 seconds faster than that of a v8 supercar, despite the fact that the v6 is only putting out about 270kw, in a car that weighs 650kg and has more downforce than the v8 supercar, which puts out over 450kw and weighs about twice as much at 1355kg. but that doesn't mean anything. the v6 must be a better motor because it powers a car that does a faster lap time....... and the 1.6L motor in the formula fords that puts out less than 100kw must be a better motor than the v8's in the commodore and falcon utes because it can lap around eastern creek around 12 seconds a lap quicker. that also has nothing to do with the fact that there is about a 1000kg weight difference between the 2 cars.....
as for that drag car, bit hard to compare that to what is found in the commodores, considering it is bored and stroked out to around 4.5L, runs 2 massive turbos, etc. and there are sr20's running close to that time. and 2jz powered cars are into the 6's, so they are obviously better, and they are smaller.
but the point still remains that bang for buck, a v6 out of a commodore is going to give less power and reliability than a stock rb25.
Yes I agree power to weight and power delivery is everything in motorsport.
Also I believe the Gary West car is a 4.9 litre Buick V6 motor revving to just under 9000rpm.......I guess he could have used an RB.
Stock for stock I think the V6 may have more (or very close) power and torque at 195kw @ 6500 rpm and 340nm @ 2600 rpm, respectively, compared to the RB.
As for reliability and cost....the Commodore and Falcon sixes have spawned a whole race class based on low cost reliable racing. I guess the success of the class speaks for itself.
But if it were my choice I'd slot in a LS2....light, compact, cheap, reliable, economical for the performance with the 6 speed, better overall power curve and huge aftermarket support, plus the stock computer can be tuned to suit some fairly serious levels of mods. Refreshingly simple really.
that is only for the newer alloytech 3.6L v6 (which isn't supercharged), and the better of the 2 versions. the base version is 175kw and 330nm. if you look at the figures for the old 3.8L they aren't as good. the supercharged version only put out 171kw, but had more torque at 375nm, and the NA version is 152kw and 305nm. so if you compare the engine that was originally talked about in this thread, you are looking at a 171kw engine vs 184kw from the rb25. now the torque of the commodore is more, but the other thing to remember is that the rb25 can be tweaked to be making 50 or 60kw more and only be limited by the ecu and turbo. the stock internals will take a fair bit more. in the case of the v6 the stock internals won't take that much more. the other thing to consider is the fact that the supercharged v6 only came in auto form, so you have to go through the hassle of converting it to manual, which isn't as easy as converting other cars (if you want it manual that is).
as for the commodore race series, etc, the engines they use in them are rebuilt, that is why they are reliable. yes there are aftermarket parts that will make them reliable for race use, but the stock parts won't take power increases that well.
i too would either be going an LS2 or RB25/30 or nissan v8. basically anything other than the holden v6
problem is that they are a cast iron block (like the rb series engines), so heavy as hell. also doubt they would fit easily due to them being a longer motor and taller motor and probably wider motor. as well as the gearbox being much bigger.
would be good to see done though. certainly plenty of poke in the motor. especially if done using the new 310kw motor. a flat 565nm of torque from under 2000rpm all the way up to 5200rpm. and in a car that weighs (once you take into account the heavier motor, etc) probably 200 to 250kg lighter than the falcon.
ahahaha, damn you beat me to it. i have a mate with a rx7. seems to be that you don't service them every few months (or 5000kms), you rebuild them, LOL. he once had to rebuild it after 6 months and it hadn't even been started.
hey inregards to what u said about rx7, sorry to be out of topic here, but my mates is about to buy an FD rx7, is da car highly maintenance car?? do u have to service it on the spot??
oh no you don't have to service them. you just have to rebuild them both before and after every trip to the shops, LOL.
nah they aren't that bad, just have a reputation as being unreliable once given a hard time. the newer ones are much better.
aaron you are from gympie (like myself) so you should know that the commodore motors are the best and most powerful engine ever made and would be the best conversion you could do to any car, LOL. just ask any of the people who do laps up the street every day.
I reckon a well set up RB25DET would be more than enough , if you can get tyre fryer power out of them in an R33 GTST then it would be same deal in a slightly lighter car and the conversion is straightforward .
I reckon one you break traction big time any more performance is a waste of time and money and probably makes it a lot harder to drive .
I think a street sorted 260 Kw Rb25 - head/cams/inlet manifold/injectors/bolt on turbo/pipes/GTR IC/PFC etc - done .
A .
I think those dissing the Buick V6 fail to realise they wern't designed as a high revving performance motor....so very far from it. Rather a low revving motor with good bottom end torque built to last. For those that know there bikes IMHO there the 'XR' of cars
From experience my ol bunky VN passed along hte generations is still going strong. My m8 has it now with the original motor unopened. reads 400,000km +. He hasnt bothered to change the oil in the last 45,000 (i was the last to change it). This is not the only one i know off.....
After 400,000klm's you never need to do an oil change.....you top the oil up....it leaks out the bottom.....you top the oil up next week...it leaks out the bottom the following week....and so on. New oil every week. :D
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
