Thanks for the advice Gary. It's because this person has been wrong on lots of topics in the past that I doubted what they were saying. I wasn't ignoring their advice, just questioning it because he didn't make an effort to explain exactly what he was saying - hence I posted on here. And I never listen to someone unquestionably; two minds in disagreeance reach a higher truth than two in agreeance. I should point out that I am not intending to lower my car car anymore than it is - it is already slightly lowered on GAB coilovers and I am satisfied with the ride height. Whether it was alligned to suit this at the time of installation I am unsure of; the previous owner did it. I say "installing coilovers" because that's what they are...I don't think I implied anywhere that Skylines don't come with factory coilovers.
The car is a daily driver so I'm not overly concerned with handling. The reasons I'm installing Teins are because the current GAB setup is rooted, the spring rates are way too firm for the street, I want to retain the freedom of adjustable height, and the front springs have next to no play in them or room for adjustment - someone told me these springs look like they were meant for an R32. However I am a perfectionist when it comes to installation so if there is a procedure that needs to be done for things to be 100% then I'm more than open to having it done.
To clarify, will it be fine to install the coilovers and get the suspension alligned a couple of days after installation? My suspension expert is about half an hour drive from me and is only free on certain days. How long does allignment usually take?
A few days won't matter, I was simply suggesting that you get the alignment checked soon after making changes if you care about the handling.
This is what is usually needed for each height increment, note that all measurements are centre of wheel to guard as usual;
Standard (new) height is 380 mm front and 370 mm rear
360/350 mm needs only the standard rear camber adjusters
350/340 mm needs 1 front camber kit and 1 rear camber kit
340/330 mm needs I front camber kit and 2 rear camber kits
BTW, R32GTST and R33GTST front springs are pretty much the same, so I don't see any logic in "someone told me these springs look like they were meant for an R32". More to the point, the rear shocks are quite different R32 to R33, so if the kit (front and rear, springs and shocks) fits an R33 then it definitely wasn't an R32 kit.
Cheers
Gary
Thanks again Gary. Will do a measure this arvo when I put them in. It was one of the places I went to when trying to source the Teins that told me the front coilover springs looked like they were from an R32. He said this because there was barely any travel available in the spring and the height adjuster was as far down the shock as it could go. Might have had no idea what he was talking about? I do agree with him that they don't look like they are meant to be there, however, as I can see myself there is no travel for the spring. It looks half compressed.
Nisskid, FFS man, what information could I have included in the original post that wasn't there and could stop you from assuming they are factory coilovers? I told you in the body of the original post that I had Tein SS going in. I can't clarify much more beyond "Tein SS" that they are aftermarket, adjustable coilovers. I thought the question was pretty friggen detailed compared to alot of the umbrella questions posted on here.
dunno why we are even arguing about this. all gary did was point out a technicality in your post, and he was right.
He pointed out an assumption that you people make, not me - why is that my fault? And the assumption was not only incorrect, it was based on false information to begin with...because...for the third time...it was stated in my unedited original post that I was installing Tein SS. How you can ignore the existence of this black and white evidence is beyond me.
You quoted previously, "I suspected as such too. This guy does like to argue for the sake of arguing or whenever there's a way to show off some knowledge."
There's more than one of them out there. He likes to have the last word too, wait for it..........
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
