Moodles2 Posted June 4, 2009 Share Posted June 4, 2009 I emailed Pete (NewKleer on here) about the possibility of running another groupbuy, only problem is he doesn't have the time to run one, but he is willing to give a groupbuy discount on the Consult LCD V2 Displays if someone is willing to run the groupbuy. I'm just trying to gauge the interest RRP is $228 delivered for the normal green display, $233 delivered for blue display. Basically you get what you see in the pictures, and a USB A-B cable + dust plug for the USB port. Has a consult passthrough builtin (the pictured usb plug in the bottom left corner) that will let you use free Consult software with your ECU like these, Nistune and other commercial Consult software should work fine as well. Group buy prices: 5-10 displays $200+8 express postage = $208 ($213 for blue) 11-20 displays $190+8 express postage = $198 ($203 for blue) 21-30 displays $180+8 express postage = $188 ($193 for blue) Pickup will probably be possible from the supplier for Sydney siders, though you would have to organise a suitable day and time with NewKleer for pickup. More info on the product: http://ecutalk.com/consultlcd.aspx Can find more info about the product in past groupbuys: http://www.skylinesaustralia.com/forums/Ec...Di-t228314.html (the current V2 Display) http://www.skylinesaustralia.com/forums/Ec...pl-t130985.html (the old V1 Display Link to comment https://www.sau.com.au/forums/topic/273204-eoi-ecutalk-consult-lcd-v2-displays/ Share on other sites More sharing options...
Moodles2 Posted June 5, 2009 Author Share Posted June 5, 2009 When/if the groupbuy will go ahead, won't be able to start until the early next month as his supplier of the LCD parts themselves are out of stock. As for groupbuy numbers, need 4 others minimum (as I'm getting one myself) to get the $20 discount, though ideally I would want to run the groupbuy long enough to get 10 others for the $30 discount. Though would be nice to get 20+ others to get the $40 discount. Link to comment https://www.sau.com.au/forums/topic/273204-eoi-ecutalk-consult-lcd-v2-displays/#findComment-4638503 Share on other sites More sharing options...
BoneZx Posted June 8, 2009 Share Posted June 8, 2009 if you want mate you can get in on the one i'm running. http://www.aus300zx.com/forum/showthread.php?t=289860 Link to comment https://www.sau.com.au/forums/topic/273204-eoi-ecutalk-consult-lcd-v2-displays/#findComment-4642792 Share on other sites More sharing options...
BoneZx Posted June 12, 2009 Share Posted June 12, 2009 moodles2 your in. will send details near the end of the month. I NEED ONE MORE PERSON FOR THIS GROUP BUY. Link to comment https://www.sau.com.au/forums/topic/273204-eoi-ecutalk-consult-lcd-v2-displays/#findComment-4652920 Share on other sites More sharing options...
BoneZx Posted June 17, 2009 Share Posted June 17, 2009 moodles2 send me a email to [email protected] if you are still wanting in. cut off date is the 27th Link to comment https://www.sau.com.au/forums/topic/273204-eoi-ecutalk-consult-lcd-v2-displays/#findComment-4662146 Share on other sites More sharing options...
R31Nismoid Posted June 18, 2009 Share Posted June 18, 2009 Please update in accordance with Forum Rules http://www.skylinesaustralia.com/forums/Th...Gro-t81129.html Failure to do so will see your GB closed. Thanks Link to comment https://www.sau.com.au/forums/topic/273204-eoi-ecutalk-consult-lcd-v2-displays/#findComment-4665359 Share on other sites More sharing options...
