  • Replies 112
^ ahh nice whats in your marine tank?? Tell me more :huh:
I got a 4*2*2 mixed reef.. corals, fish etc..
Yea its hard to take pics of fish since they move around so much!!
Just quicker shutter speed and perhaps a bump in ISO will help.
Edit: oh you got a digi cam.. hmm yea i guess it could be harder.. Never tried with a digi cam.. Might do it tomorrow and see if i can get any good shots.
Edited by siddr20
Hey mate,
I got mostly angel fishes, corals r easy to keep in winter, but they will die easily in summer at least u hav a cooler or turn ur aircon on everyday. haha
it's impossible to take photos wif dc, too slow~
i've got my tank for more than one year now, so it's pretty easy to keep~
don't put too many fishes yet as u've just started, make sure to check the water every few days, and clean ur glass, if not...haha...will b hard 2 clean!
cheers
^ ahh nice whats in your marine tank?? Tell me more :P
Yea i have a chiller.. Haven't plumbed it up yet, but will do it soon.
This is my setup:
System Type: Mixed Reef!!
Display System:
Strike up Date: 10/04/2009
Display Tank: 4*2*2. Back painted black!!
Display Lighting: Arcadia Series 3 slimline pendant 2 x 250w
Stand: Made my own. 1.23m by 1m by .7m.
Hood: None. Open top!!
Sump: 2ft*18*18 with two baffles in place.
Refugium: None as yet.
Refugium Lighting: None
Support systems:
System Water: Natural salt water purchased at Aquarium stores.
Display Water circulation: 2* JVP 12000L/H power head. So total 24,000L/H.
Return Pump: 4000L/H no name type
Skimmer: Reef Octopus Vortex 800
Evaporation Top Up:4 Stage PSIFilters RO/DI Unit
Chiller: Teco RA-680 Chiller
Live Stock:
- 2 ocellaris Clown fish with one being black n white
- 1 Yellow tang
- 1 6 line wrasse
- 2 hermit crabs
- 2 large snails + plus 5 small little ones
- 1 x very large clam (and i mean very large)
- 4 Green Chromis.
Corals:
cataphylia (elegance coral)
Australian Duncan Coral
Trachaphyllia
SPS Acro (blue)
Finger Leather Coral
Plus other bits and pieces
Pictures:
Did a huge re-acquascaping today. Still a bit more to do on the right side.. But getting there slowly!!
Before: http://i575.photobucket.com/albums/ss200/s...kshotresize.jpg
After:
Yea i do regular water changes etc.. Calcium is about 430ish now.. phosphate 0.. which is great :P
Indeed its pretty easy to keep!!
Post up your tank pics :wub:
  • 4 months later...
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
