Hi my car is non turbo but this is where eveyone read... Turbo or not no different here
i was getting a huge misfire on the way home and the car almost stalled when i pulled up...
i done the trick where u unplug the coilpacks 1 at a time while car was running to see whats working...
4th was not doing nething... pulled the spark plug out and the bottom of it where is sparks has broken off into my engine (wtf)
it was a NGK INGNITION plug and only maybe 6 months old so (wtf)???
nehow i thought its stuffing up ill degrease and sray clean my engine... let the car dry for a day/night before testing it out with the new spark plug,
it got better for a tiny bit say 1km up the road and then bam... it started again i put my foot down and it sounds like a really freakish rotary noise does not sound healthy at all.
but then at times it goes away for a second...
any ideas on what it might be... my injectors needed to be cleaned i was told by a dude that dyno'd my car a while ago...
but what im most concerned of is that bit of metal from the spark plug that was in the engine when i turned the car on i heard it and it went away?!?!?!
where could it have gone would it be sitting in my sump?
im know im in a f$%kd up position but please just write back helpfull information... on the misfire and where that metal could have gone to
thanks.... P.S. please dont just tell me to goto a mechanic, as it would be obvious... ide like to fix the problem myself
https://www.sau.com.au/forums/topic/273258-engine-problem/
did you check your coil packs? also you said you water sprayed your engine..... Usually this happends when you dont cover your alternator or your coil packs.. To me it sounds like winter went through your engine.............
https://www.sau.com.au/forums/topic/273258-engine-problem/#findComment-4637769
yes the rubber on the side of the centre platic plate had been warn off and there was water down there so i got a compresser and blew it out the best i could...before changing the plug
so wat could be happening there? will it ever be fixed by driving it?
https://www.sau.com.au/forums/topic/273258-engine-problem/#findComment-4637852
What gap are you running on your plugs?
im not sure on the gap size i just asked the for plugs from autobarn and i found out the plugs are... " NGK IRIDIUM ix "
if the gap is to big or small could it cause a problem like this?
cause maybe they gave me turbo plugs.
https://www.sau.com.au/forums/topic/273258-engine-problem/#findComment-4637856
Does the plug look broken or melted?
We need to see a pic of the plug itself, you have a fairly serious problem!
i gave it to autobarn to throw out when i got a new 1 but this is a pick of what happened...
the plug was normal just a bit oily since the black rb25 cover never sat properly
https://www.sau.com.au/forums/topic/273258-engine-problem/#findComment-4638816
rip the head off the motor, rip the turbo off and pull out your cat - it will be in either one of these.
chances are its sitting ontop of, or stuck between the piston and the bore. if it is you dont want to risk any dodgy attempts at getting it out, using a magnet wont be good enough as there will still be fragments that will cause bore damage.
rip your turbo off and make sure no pieces are in there or have caused one of the fins to chip, and if they have passed through they will most likely be in your cat.
goodluck!
https://www.sau.com.au/forums/topic/273258-engine-problem/#findComment-4638834
goodluck!
hey man thanks for the info... its not turbo atm but that doesnt matter... when i turned the car on i didnt hear nething but when i drove up the street i heard it hitting the top of my engine... so i turned around and went home but on the way back that noise went away so where do u think it would most likely be as i will look at it tomorrow?
https://www.sau.com.au/forums/topic/273258-engine-problem/#findComment-4639160
Stuck down the exhaust near the cat or out the back of the car if the cat didnt stop it.
Worse case scenario its still in the cylinder bore.
I'd check the cat first. If you cant find it, pull off the head and have a look. You'll also find the damage its done.
Is it possible they gave you the wrong length plugs and the pistons are hitting them? Or just no.4 like you said?
Edited by nIsMo86
https://www.sau.com.au/forums/topic/273258-engine-problem/#findComment-4639399
Sh#t didnt realise the piston could get that close to hit a spark plug?!?!
should i ring them and check that its the right size plug for a non turbo engine
https://www.sau.com.au/forums/topic/273258-engine-problem/#findComment-4639524
that bit that broke off is probably sitting in ur exhaust pipe sumwhere, it isnt the main concern at the present time.... u need to find out why the engine is missing....
try pulling out all your plugs and make sure they are all the same (none broken, make sure they all have the same colour on the electrode end) mix them around (so put the 4th one in the 1st cyl) and put it all bak together and run it....note if it still misses and what cylinder is still missing
next pull out ur coilpacks and check for external cracks around the body of each coil.... if there is any, best off replacing it now....put them back in and also move them around (so put the 4th one now in cylinder 2) and start it and see how it goes....
what your trying to do is isolate if the missfire moves..... if you have moved your spark plugs and your coils around and the miss is still in the 4th cylinder then u know is either mechanical or your injector. and if you find the miss is still in the 4th cylinder.... pull your injectors out and get them cleaned, put them back in and test again....
after all this probably do a compression test on all cylinders to see if that bit of metal has done any damage...
do all this first before u go ripping ur head apart.... and get bak to us.....
https://www.sau.com.au/forums/topic/273258-engine-problem/#findComment-4639969
