was told mrs @ home got delivery of a box from NSW... that'll be my grounding kit I suppose... :)
can't wait to get my hands dirty this weekend... shouldn't be too hard to install?
except the transmission point though, I'm not so sure about that... I heard it can be tricky.
wow. that was fast!
shouldn't be too hard for you to install, ive done mine last nite, shouldnt be any problems for you guys. haha
just to make sure u swap the connection the other way around for wire 2 and wire 8.
sxexcx's instruction:
Wire #2 suppose to connect to the battery
Wire #8 suppose to connect to the Grounding point on the Brakes compartment.
JDM install:
Wire #2 connect to the grounding point on the brakes compartment
Wire #8 connect to the battery
  • Replies 212
got mine installed today!
bloody postman didn't leave the card in our mail box, ended up up chasing fox and get the registerd nos to get info from aust post then found out it was sitting at post office n waiting collection!
tnx foxxx!
i've replaced bolt where wire 1,2,3 & 4 connected, i think bolt was too short couldn't tighten the bolt!
do we really need to reset the ECU?
hm didn't think of that the bolt will be too short...
what did you replace it with?
the guy who made it should have put thinner end terminals... or maybe since it's for USDM, should the bolt from the opposite side of the plenum is longer?
I was installing plenum spacer at that time so I have some spare bolts, actualy I used the spare bolt to replace the one that mounts the stock intake and used the bolt from stock intake to side of plenum that mounts the bracket that holds the main wire loom (where the four grounding wire were connected).
I f###D up!
I have broken one of the bolt supply with the plenum spacer... toooo much torque! bloody torque wrench!
no worries ed,
yea. i couldnt tighen the bolt for wire 1234 too. i ended up using the 2 bolts from the engine cover,
the bolt from the opposite side of the plenum is longer, but ull have 3 wires there wif ur intake holder so i don't think u can swap wif that one, the best u can do is swap wif the engine cover ones.
do you need a torque wrench to install this ground kit? as those are the plenum spacer bolt it's attaching to
rianto, none of the grounding kit wires will be connected to the bolt of plenum spacer!
most of those grounding wires will be connected to the stock grounding!
if one of he bolt is a bit shorter & couldn't be tighten you can get a replacement bolt from repco...
thanks for the info. may not have time to install it tomorrow as my mrs just gave birth to our little baby boy less than 2 hours ago!
Hey Fox, thanks for organising the Group Buy once again. I installed mine yesterday, noticeable difference in the shifting. I didn't have to change any bolts, the wires all went in perfectly. I had a lot of trouble getting to the Transmission bolt though, well got it out easy enough, but had trouble putting it back in!
rs73, Grats on the baby boy mate! :P
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
