was told mrs @ home got delivery of a box from NSW... that'll be my grounding kit I suppose... :)
can't wait to get my hands dirty this weekend... shouldn't be too hard to install?
except the transmission point though, I'm not so sure about that... I heard it can be tricky.
wow. that was fast!
shouldn't be too hard for you to install, ive done mine last nite, shouldnt be any problems for you guys. haha
just to make sure u swap the connection the other way around for wire 2 and wire 8.
sxexcx's instruction:
Wire #2 suppose to connect to the battery
Wire #8 suppose to connect to the Grounding point on the Brakes compartment.
JDM install:
Wire #2 connect to the grounding point on the brakes compartment
Wire #8 connect to the battery
  • Replies 212
got mine installed today!
bloody postman didn't leave the card in our mail box, ended up up chasing fox and get the registerd nos to get info from aust post then found out it was sitting at post office n waiting collection!
tnx foxxx!
i've replaced bolt where wire 1,2,3 & 4 connected, i think bolt was too short couldn't tighten the bolt!
do we really need to reset the ECU?
hm didn't think of that the bolt will be too short...
what did you replace it with?
the guy who made it should have put thinner end terminals... or maybe since it's for USDM, should the bolt from the opposite side of the plenum is longer?
I was installing plenum spacer at that time so I have some spare bolts, actualy I used the spare bolt to replace the one that mounts the stock intake and used the bolt from stock intake to side of plenum that mounts the bracket that holds the main wire loom (where the four grounding wire were connected).
I f###D up!
I have broken one of the bolt supply with the plenum spacer... toooo much torque! bloody torque wrench!
no worries ed,
yea. i couldnt tighen the bolt for wire 1234 too. i ended up using the 2 bolts from the engine cover,
the bolt from the opposite side of the plenum is longer, but ull have 3 wires there wif ur intake holder so i don't think u can swap wif that one, the best u can do is swap wif the engine cover ones.
do you need a torque wrench to install this ground kit? as those are the plenum spacer bolt it's attaching to
rianto, none of the grounding kit wires will be connected to the bolt of plenum spacer!
most of those grounding wires will be connected to the stock grounding!
if one of he bolt is a bit shorter & couldn't be tighten you can get a replacement bolt from repco...
thanks for the info. may not have time to install it tomorrow as my mrs just gave birth to our little baby boy less than 2 hours ago!
Hey Fox, thanks for organising the Group Buy once again. I installed mine yesterday, noticeable difference in the shifting. I didn't have to change any bolts, the wires all went in perfectly. I had a lot of trouble getting to the Transmission bolt though, well got it out easy enough, but had trouble putting it back in!
rs73, Grats on the baby boy mate! :P
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
