  • Replies 212
hahah yeh it is
hey for that price even i may give it a go
when do you plan on making payment?
will be about $140-150 aud correct?
-mark
hey Mark,
im not sure about the current exchange rate tho, but i think it wil b around that price
i wanna do it as soon as i can get 10 ppl~ but till now only 3 ppls~ lol
Fox
add me to the list - Red colour
and yes also find out if it is suitable for the RHD cars since our battery etc. is on the opposite side of the car.
this kit looks like the wires are the EXACT sizing, so, it might be a problem if it wont reach the grounding points.
Edited by BLISTC
Thanks Mark,
I've asked him and he said it will fit, but i will double confirm, and im also waiting for the review on our forum member who has installed this kit few days ago. Hope he can give us some info when he see this.
update:
1. FoxV35 (BLUE)
2. moomoolulu (colour?)
3. danny_tg (colour?)
4. BLISTC (RED)
I would be very interested!! Please add me in!
USD115 shipped for a custom kit is a lot cheaper than the Pivot Volt Stabilised I was initially planning to buy...
Yes ill add u in, thanks.
USD 115 is really a good price, i was thinking to get Volt Stabiliser as well, but ppl said the grounding kit is more useful, so yea. might go for a try~
Update:
1. FoxV35 (BLUE)
2. moomoolulu (BLUE)
4. BLISTC (RED)
5. Saglapian (colour?)
6. MILLOS (BLUE)
I'm in as well guys!!!
nicenice~
ur from Carlton? the one in sydney? haha...let's go for a chat later. haha~ im goin there for dinner now
3. danny_tg (Black any? or Blue then red, but still considering.. 70% sure)
hi~ i dun think there's any black ones, there's a coke colour. but haven't seen it b4~ lol
plz put ur name down if ur 100% sure. when it reach 10 ppls n ill purchase it
Are the G35 engine bays the same as ours? Are our batteries to the left or to the right?
PS. I would like black in colour if possible, if not red. Cheers!
it will be 100% fit on our car. im very sure
and there's no black in colour. sorry~ u want me 2 put it Red for ya? thx
same engine bays,, our batteries are on the right side,,
hey guys just putting my input. I have bought the kit from sxexcx's and put it onto my V35. Everything fit 100% and the only problem is the battery was on the other side. Therefore putting my idea i basically swap the connection the other way around.
sxexcx's instruction:
Wire #2 suppose to connect to the battery
Wire #8 suppose to connect to the Grounding point on the Brakes compartment.
My install:
Wire #2 connect to the grounding point on the brakes compartment
Wire #8 connect to the battery
The improvement i have is the Car definitely running much smoother and more responsive. The Auto Gear shift also crispier and noticeably quicker.
The DIY term is pretty easy install for the engine bay, except the Auto transmission point. You have to go underneath the car to install it.
I cannot provide the Dyno results as this mod is not to increase Horsepower/KW, but to improve the responsiveness and smoothness of the VQ35 and shifting time on the CVT Auto Transmission.
Also the kit should fit on the Sedan with VQ35 as well.
hope my review helps
Edited by pw350gt
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
    • The log you did with ECU voltage, can you log the other things too like rpm and oil pressure? Need all that info together to compare easily
