Got a few things for sale, in Adel, west suburbs. all prices negotiable. contact me on 0422976559
6boost low mount steam pipe manifold with 50mm turbosmart pro gate with screamer, suit rb25 1000kms old all for $1700
sard 850cc injectors in standard rail suit rb25, injectors 1000kms old all for $800 also comes with modified injector loom to suit
Nismo fuel reg SOLD
Garrett gt30/82 turbo approx 5000kms old, made 300rwkw on my 25 340rwkw on e85, awesome midrange/topend power n torque
used with 6boost manifold n gate, full boost (23 psi) 4100rpm comes with 3 inch dump $1600
Tomei pon cams suit rb25 s1, 256 dur $800 good cond, used for approx 5000kms
Splitfire coil packs suit s1 rb25/rb20 and rb26, 1000kms old $500
BLITZ number plates, gold lettering on black background. $600 ono
ISC N1 fully adjustable coilovers suit r33 gts-t as new approx 5000kms old $1100
https://www.sau.com.au/forums/topic/273279-r33-rb25-performance-parts-adel/
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
