Proximity Motorsport Posted June 5, 2009 Share Posted June 5, 2009 (edited) Hey, Just spoke to the guys at competition coatings, and they were telling me they silver coating isnt good enough for the rear housing, and they need to use the black coating, which is more expensive, and not as appealing to the eye. He said he has done a few in silver, but mainly for show cars, and if they get too hot they go grey, he said it doesnt look too bad. Just wondering if anyone has done silver, or got any pics of a silver one, thats gone grey. cheers Edited June 5, 2009 by choku_dori Link to comment https://www.sau.com.au/forums/topic/273287-hpc-coating-turbo-rear-housing/ Share on other sites More sharing options...
TiTAN Posted June 5, 2009 Share Posted June 5, 2009 check with 2rismo, his turbo has the silver HPC coating. Link to comment https://www.sau.com.au/forums/topic/273287-hpc-coating-turbo-rear-housing/#findComment-4638282 Share on other sites More sharing options...
2rismo Posted June 5, 2009 Share Posted June 5, 2009 It's fine and looks great. Do it. Link to comment https://www.sau.com.au/forums/topic/273287-hpc-coating-turbo-rear-housing/#findComment-4638405 Share on other sites More sharing options...
Duncan Posted June 7, 2009 Share Posted June 7, 2009 My dumps are silver coated and have been fine with the heat. no sign of colour change Link to comment https://www.sau.com.au/forums/topic/273287-hpc-coating-turbo-rear-housing/#findComment-4642069 Share on other sites More sharing options...
NYTSKY Posted June 7, 2009 Share Posted June 7, 2009 My manifold and rear housing are both silver. They do go a bit dull after a while but it still looks the goods. Link to comment https://www.sau.com.au/forums/topic/273287-hpc-coating-turbo-rear-housing/#findComment-4642121 Share on other sites More sharing options...
GT-RZ Posted June 7, 2009 Share Posted June 7, 2009 yea normally the coating will go powdery and come off a bit but it stays a duller version of the colour you put on most the time... make sure you get it blasted or acid cleaned before you do it though otherwise its a waste of time. personally anything that is getting a bit of surface rust like exhaust manifolds or whatever i just dip/spray it in phosphoric acid which chemically turns the surface black/gray and it stays that way. phosphoric acid also works really well for brightening/ cleaning aluminium and is allot safer than the hydroflouric/nitroc acid mixtures. Link to comment https://www.sau.com.au/forums/topic/273287-hpc-coating-turbo-rear-housing/#findComment-4642596 Share on other sites More sharing options...
petern Posted June 9, 2009 Share Posted June 9, 2009 I got mine done at Sydney's competition coatings over a year ago now. The main areas still has a shine to it, but pretty sure it won't go dull like you see on the inside Link to comment https://www.sau.com.au/forums/topic/273287-hpc-coating-turbo-rear-housing/#findComment-4645038 Share on other sites More sharing options...
gtr fan Posted September 15, 2009 Share Posted September 15, 2009 If you have the exhaust housings and manifolds coated, would it be safe to remove the heat shields? Link to comment https://www.sau.com.au/forums/topic/273287-hpc-coating-turbo-rear-housing/#findComment-4827517 Share on other sites More sharing options...
dano4127 Posted September 15, 2009 Share Posted September 15, 2009 yea normally the coating will go powdery and come off a bit but it stays a duller version of the colour you put on most the time... make sure you get it blasted or acid cleaned before you do it though otherwise its a waste of time.personally anything that is getting a bit of surface rust like exhaust manifolds or whatever i just dip/spray it in phosphoric acid which chemically turns the surface black/gray and it stays that way. phosphoric acid also works really well for brightening/ cleaning aluminium and is allot safer than the hydroflouric/nitroc acid mixtures. just to double check that is basically what Rust Converter is right? Link to comment https://www.sau.com.au/forums/topic/273287-hpc-coating-turbo-rear-housing/#findComment-4827561 Share on other sites More sharing options...
Craved Posted September 15, 2009 Share Posted September 15, 2009 Well the silver Comp coatings is using is good for 1600oF - they should know well enough that they can use a special primer to raise that threshhold up to 2000oF to match the blacks rating. couple of hints : -clean hands and no oil on the parts before using it for the first time will ensure maximum shine -you can repolish the chrome coating with metal polish, just remember to use methylated spirits to clean off the polish residue before starting the car up again I use the same products that they are listed as a distributer for - Leon if you want some extra info chat me Link to comment https://www.sau.com.au/forums/topic/273287-hpc-coating-turbo-rear-housing/#findComment-4827584 Share on other sites More sharing options...
GT-RZ Posted September 15, 2009 Share Posted September 15, 2009 just to double check that is basically what Rust Converter is right? yea rust converters mainly use phosphoric acid. but generally allot of them come in stupid gels or creams and turn brown. pure acid makes it black and leaves no coating. Link to comment https://www.sau.com.au/forums/topic/273287-hpc-coating-turbo-rear-housing/#findComment-4827623 Share on other sites More sharing options...
W0rp3D Posted September 15, 2009 Share Posted September 15, 2009 (edited) Any idea what it would cost to do an ehaust manifold, one piece split dump and exhaust housing? No chrome tho, just a factory looking grey or black. Edited September 15, 2009 by W0rp3D Link to comment https://www.sau.com.au/forums/topic/273287-hpc-coating-turbo-rear-housing/#findComment-4827991 Share on other sites More sharing options...
