Hey,
Just spoke to the guys at competition coatings, and they were telling me they silver coating isnt good enough for the rear housing, and they need to use the black coating, which is more expensive, and not as appealing to the eye. He said he has done a few in silver, but mainly for show cars, and if they get too hot they go grey, he said it doesnt look too bad. Just wondering if anyone has done silver, or got any pics of a silver one, thats gone grey.
cheers
Edited by choku_dori
https://www.sau.com.au/forums/topic/273287-hpc-coating-turbo-rear-housing/
yea normally the coating will go powdery and come off a bit but it stays a duller version of the colour you put on most the time... make sure you get it blasted or acid cleaned before you do it though otherwise its a waste of time.
personally anything that is getting a bit of surface rust like exhaust manifolds or whatever i just dip/spray it in phosphoric acid which chemically turns the surface black/gray and it stays that way.
phosphoric acid also works really well for brightening/ cleaning aluminium and is allot safer than the hydroflouric/nitroc acid mixtures.
  • 3 months later...
just to double check that is basically what Rust Converter is right?
Well the silver Comp coatings is using is good for 1600oF - they should know well enough that they can use a special primer to raise that threshhold up to 2000oF to match the blacks rating.
couple of hints :
-clean hands and no oil on the parts before using it for the first time will ensure maximum shine
-you can repolish the chrome coating with metal polish, just remember to use methylated spirits to clean off the polish residue before starting the car up again
I use the same products that they are listed as a distributer for - Leon if you want some extra info chat me
Any idea what it would cost to do an ehaust manifold, one piece split dump and exhaust housing?
No chrome tho, just a factory looking grey or black.
Edited by W0rp3D
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
