hey guys, I need some help, with obtaining measurements of an rb26 N1 block.
any help will be very appreciated, please specify what points you are measuring from, and if possible please include pictures of every possible angle of the block (front, back, top, bottom.etc).
thanks guys
https://www.sau.com.au/forums/topic/273293-rb26-n1-block-measurements-and-pics/
common guys, we need measurements from the following points:
center of crankshaft to top of block
top to bottom of block (front), back to front (top and side) longest points
need lengths of spacing in the cradle (edge to edge-please specify where you measured) need width of cradle journals.
please, any help will be appreciated
I think its a case of no one just having N1 blocks sitting around. :)
Best bet is to just buy one if you need to do anything specific with one
just a bit to expensive for us at the moment mate, could someone just measure up a standard one from the specified points please?
I also would...but I only have the RB26DETT...not N1.
sorry.
would you be able to grab some of the standard block please mate? It seems no one has an N1 block at the moment.
If anyone has an rb26 block for sale near brisbane we will buy one to get measurements.
thanks for the reply's guys.
cheers
sorry.
cheers
On that note, I am guessing a RB26 N1 Block is the size as the Normal RB16 block as it is the same engine, just made from stronger material.
N1 blocks are cast from the same parent material as 05U blocks. The difference is thicker cylinder walls and deck thickness to prevent bores splitting and cracking around the head studs which 05U blocks are prone to.
Thanks for clearing that up! :down:
But size wise it is still the same..?
cheers
Sure, can measure it tomorrow if you want. from which points? just length and width of the block itself?
I have a RRR block sitting on my stand waiting for my car to arrive. I can measure that on the weekend if you like.
Let me know ...
yeah thanks mate, that would be well appreciated,
hey mate, yeah from the above points, and any diagonals. that would be great
cheers guys, thanks for the intrest
Let me know ...
want to sell that block? or swap + cash your way for a brand new N1 block.... :P ?
    • I have two German Shepherds that like to bite things that are in places they shouldn't be. Plus the cars/batteries on chargers are inside a locked garage, inside that fully fenced and locked yard. If you can get the car out, you can have it, as I'll be having one hell of a laugh at your expense.
    • Looks like they changed the wording in the manual for the new model. I have a different model. Mine is CC1206. Not CC1206-XLI. Mine doesn't support lithium at all. I can't find the manual for my model online and they don't list the model on the Century website anymore either. In my manual it says what I quoted and that they recommend to not leave it on 🤷‍♂️ Sounds like you'd be fine with this one now.
    • Thanks for actually answering every single point! I noticed the date only after posting. And yes, looks like things have changed a little bit since then. FWIW, looks like Government Gazette No 253 has the current emissions test procedure. Sounds pretty reasonable altogether. One thing I learned from this is that it's possible to check whether a catalyst does any work by measuring the temperature. Catalyst outlet temp is at least 40°C higher than inlet temps if there is a reaction happening. I'd be curious to check this on mine but don't have a thermometer. Because purely going by smell it can't be doing much. Personally I'd be okay to pay for the test as long as it's within reason. My main concern would be to lose my rego because it definitely wouldn't pass the test in its current state. I'll see if I can do a bit more digging and see what's involved in doing this nowadays.   To be fair I don't think it's stopping many people from doing the modifications anyway. It just puts a barrier up to doing things right
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
