Item:1994 TOYOTA ARISTO
Item Condition: A1 WILL NOT DISSAPOINT
Price and Payment Conditions:$16,500 RWC OR SWAPS
Extra Info:
IM THE 1ST AUSTRALIAN OWNER
94 3.0V TOYOTA ARISTO
2JZGTE TWIN TURBO AUTO
JET BLACK
GETS AROUND 550KMS TO A TANK WHICH ISNT TO BAD AT ALL
-CUSCO COIL OVERS (NEW)
-FRONT MOUNT INTER COOLER 600X300 (NEW)
-FRONT MOUNT TRANS COOLER(NEW)
-18INCH KARLSON RIMS BLACK BRIDGESTONE 265'S STRETCHED ON REAR
-K&N POD FILTER WITH CUSTOM INTAKE PIPE (NEW)
-FCD (NEW)
-TXS BOOST CONTROLLER SET TO 14PSI (NEW)
-TAS PERFORMANCE 3INCH EXHAUST WITH HIGH FLOW CAT AND MUFFLERS (NEW)
-BLITZ BLOW OFF VALVE (NEW)
-AUTOMETER BOOST GUAGE(NEW)
-7INCH DVD PLAYER TOUCH SCREEN DVD/IPOD/USB/RADIO/MP4/MP3/DIVX (NEW)
-12INCH SUB 1200WATTS WITH AMP (NEW)
-AWESOME SPEAKERS WITH TWEATERS IN THE FRONT PILLARS SOUNDS GREAT UNSURE OFF THE BRAND IN THE CAR WHEN I GOT IT
-ELECTRIC SUNROOF
-ELECTRIC SEATS AND STEERING WHEEL
-AIR PURI
-ELECTRIC WINDOWS
-ABS
-TRACTION CONTROL WITH ON/OFF SWITCH
-STANDARD LSD
-CRUISE CONTROL
-HKS TURBO TIMER
I HAVE SINCE OWNING IT MAINTAINED THIS CAR TO KEEP IT FOR THE LONG RUN BUT DUE TO MOVING CITYS AND LOOSING MY JOB CANT AFFORD TO KEEP IT
SINCE I HAVE HAD THE CAR I HAVE DONE
-GATES TIMING BELT WITH NEW TENSIONER
-CAM AND CRANK SEALS
-NEW WATER PUMP/HYDROLIC FAN PUMP
-NEW GENUINE HARMONIC BALANCER ($500+)
-GENUINE BALL JOINTS FRONT (TOP AND BOTTOM)
-NEW DRIVE BELT SPRING LOADED TENSONER
-NEW POWER STEERING PUMP ($850+)
-A/C REGASED
-SERVICED IT EVERY 5000 KMS WITH FILTER CHANGED EVERY TIME
-100,000KM S WAS DONE ALL OILS AND FILTERS PLUGS ETC CHANGED.....
CAR IS WERE WELL MAINTAINED OVER ALL THE CAR IS STUNNING EXCEPT WHERE MY CAR GOT EGGED OR SOMETHING CHUCKED AT IT BUY @#$!S DRIVING PAST I WAS LUCKY ENOUGH HAD TO CUT POLISH IT WHERE IT WAS HIT AND NEEDS JUST TO BE BUFFED
CAR MADE 220HP AT WHEELS ON STOCK BOOST COMPLETELY STOCK
IT FEELS FAST TO DRIVE IM GUESSING WITH THE MODS NOW IT WOOD BE AROUND THE 270HP@WHEELS MARK
(IF I EVER FIND OUT WHO IT WAS I WILL f**kING BREAK YOUR SKULL WITH A HAMMER)
Contact Details:BROCK 0410490449
Edited by lag13
https://www.sau.com.au/forums/topic/273295-toyota-aristo/
Nice Clean R33 With Big Turbo!-- 400+rwhp
Not sure if that link will work as im new to this.
car is on carsales if you want to see it and the above link does not work. do a search for plates.. -143KBL-
let me know what you think.
thanks.
https://www.sau.com.au/forums/topic/273295-toyota-aristo/#findComment-4646421
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
