Item:1994 TOYOTA ARISTO
Item Condition: A1 WILL NOT DISSAPOINT
Price and Payment Conditions:$16,500 RWC OR SWAPS
Extra Info:
IM THE 1ST AUSTRALIAN OWNER
94 3.0V TOYOTA ARISTO
2JZGTE TWIN TURBO AUTO
JET BLACK
GETS AROUND 550KMS TO A TANK WHICH ISNT TO BAD AT ALL
-CUSCO COIL OVERS (NEW)
-FRONT MOUNT INTER COOLER 600X300 (NEW)
-FRONT MOUNT TRANS COOLER(NEW)
-18INCH KARLSON RIMS BLACK BRIDGESTONE 265'S STRETCHED ON REAR
-K&N POD FILTER WITH CUSTOM INTAKE PIPE (NEW)
-FCD (NEW)
-TXS BOOST CONTROLLER SET TO 14PSI (NEW)
-TAS PERFORMANCE 3INCH EXHAUST WITH HIGH FLOW CAT AND MUFFLERS (NEW)
-BLITZ BLOW OFF VALVE (NEW)
-AUTOMETER BOOST GUAGE(NEW)
-7INCH DVD PLAYER TOUCH SCREEN DVD/IPOD/USB/RADIO/MP4/MP3/DIVX (NEW)
-12INCH SUB 1200WATTS WITH AMP (NEW)
-AWESOME SPEAKERS WITH TWEATERS IN THE FRONT PILLARS SOUNDS GREAT UNSURE OFF THE BRAND IN THE CAR WHEN I GOT IT
-ELECTRIC SUNROOF
-ELECTRIC SEATS AND STEERING WHEEL
-AIR PURI
-ELECTRIC WINDOWS
-ABS
-TRACTION CONTROL WITH ON/OFF SWITCH
-STANDARD LSD
-CRUISE CONTROL
-HKS TURBO TIMER
I HAVE SINCE OWNING IT MAINTAINED THIS CAR TO KEEP IT FOR THE LONG RUN BUT DUE TO MOVING CITYS AND LOOSING MY JOB CANT AFFORD TO KEEP IT
SINCE I HAVE HAD THE CAR I HAVE DONE
-GATES TIMING BELT WITH NEW TENSIONER
-CAM AND CRANK SEALS
-NEW WATER PUMP/HYDROLIC FAN PUMP
-NEW GENUINE HARMONIC BALANCER ($500+)
-GENUINE BALL JOINTS FRONT (TOP AND BOTTOM)
-NEW DRIVE BELT SPRING LOADED TENSONER
-NEW POWER STEERING PUMP ($850+)
-A/C REGASED
-SERVICED IT EVERY 5000 KMS WITH FILTER CHANGED EVERY TIME
-100,000KM S WAS DONE ALL OILS AND FILTERS PLUGS ETC CHANGED.....
CAR IS WERE WELL MAINTAINED OVER ALL THE CAR IS STUNNING EXCEPT WHERE MY CAR GOT EGGED OR SOMETHING CHUCKED AT IT BUY @#$!S DRIVING PAST I WAS LUCKY ENOUGH HAD TO CUT POLISH IT WHERE IT WAS HIT AND NEEDS JUST TO BE BUFFED
CAR MADE 220HP AT WHEELS ON STOCK BOOST COMPLETELY STOCK
IT FEELS FAST TO DRIVE IM GUESSING WITH THE MODS NOW IT WOOD BE AROUND THE 270HP@WHEELS MARK
(IF I EVER FIND OUT WHO IT WAS I WILL f**kING BREAK YOUR SKULL WITH A HAMMER)
Contact Details:BROCK 0410490449
Edited by lag13
https://www.sau.com.au/forums/topic/273295-toyota-aristo/
Nice Clean R33 With Big Turbo!-- 400+rwhp
Not sure if that link will work as im new to this.
car is on carsales if you want to see it and the above link does not work. do a search for plates.. -143KBL-
let me know what you think.
thanks.
https://www.sau.com.au/forums/topic/273295-toyota-aristo/#findComment-4646421
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
