the M35 VQ25 is listed on the SAFC Neo and and SAFC II installation lists. but not the SAFC 1, which is probably not supported because the SAFC 1 would have been designed before the VQ25 was in production.
i don't see why you couldn't get it working, its just a signal bender. what were the reasons behind not having any luck using them?
  • 9 months later...
im running SAFC II works well for the limited tunability it gives. Still waiting for someone to flash the factory ECU's
Bump!
Has anyone else since tried the SAFC/AFC Neo options with their M35 stageas?
@danwatt
Can you give us some more info on the results you've had with the SAFC II?
Thanks
I'd be interested in this too. I had great results from a SAFC2 on my series 2 stagea. For the price its a bargain (2nd hand FTW), especially if the car is otherwise standard or only lightly modded.
I'm sure I read on here that the M35 ecu somehow counteracts the effects of the SAFC or something along those lines...anyone?
the problem with any piggyback computer is the ECU on the M35 is self learning.
So when you make changes the ECU tries to compensate for changes made to the input signal. Not a waste of time just very difficult.
usually the side effect of the SAFC was that it advanced the timing. But it was still good enough to get the AFR graph to flatten out once it hit 12:1 and stay at 12:1 all the way to redline. This was on a 99 model with full 3" exhaust and GT30 turbo, and with the base timing advanced a little also, the fuel economy dropped by 2L/100km. It was a huge improvement, mainly in the mid-range.
I guess the problem is that the ecu has so many inputs it uses, and with the SAFC you're only changing one of those...
    • They're supposed to not be compatible.
    • Evening fam, Pretty much what the title asks, I have looked all over and can’t find a proper answer expect one post from almost a decade ago which is vague. ive seen photos and they look pretty much identical, would an r33 GTR N1 reo work on an r32? reason I ask is they are cheaper to buy… $700 compared to 1k+ for an r32 n1 reo
    • Couldn't help myself, had to start putting it together.... It really is a solid bit of kit.  Probably stronger than i would have made it myself to be fair! 🤣🤣 Sweating like a pig after that.  Bloody hot and muggy day today, time for a swim now!
    • Yeah was thinking that. I've had the car go lower idle possibly around 650rpm every once in a long time after pouring fuel and would sound quite rough like a misfire, almost like it's shit fuel or something but who knows.
    • @Wazmond you are correct, my bad, was not my intent    https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.    I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.    I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.    https://gtrfestival.com.au
