Item:
1. Dr Drift Chipped RB20 Ecu for an R33 Skyline.
2. High flowed standard side feed injectors (800cc).
Website: Boostcruising.com & SAU.com
Item Condition: Perfect
Reason for Selling: Going back to standard setup
Price and Payment Conditions: $650
Extra Info: Tuned at Mercury Motorsport. Have receipts and dyno readout. This ECU will not need to be re-tuned for these injectors. Swap in and drive. I can install these injectors for an additional cost
Pictures:
Contact Details: PM or call Liam - 0400 124 322
RB20 and 25 are much the same. The 32 ECU does not support variable valve timing however that is only active up to 3000rpm and honestly you don't notice any difference. This ecu was tuned for an internally standard rb25 series 1 motor with the high flowed standard injectors, kkr 430 turbo running 14psi, standard air flow meter, walbro 550hp pump, and usual exhaust and intercooler mods. Obviously it can run more than 14psi if you want to. Boost was increased to 18psi and was a very quick car. 14psi is perfect for street. More power can be had with a z32 afm however you would need a re-map which is quite cheap at around $200. With the correct turbo this setup can handle 300rwkw easily on a standard motor, 270rwkw for reliability day in day out.
Edited by liampire
