R34 GTT wheels. Tyres pretty much brand new. 225x45x17 all round. Guess 95%, no camber wear.
Comes with all center caps. Great condition. Look great on r32.
With 2x 8mm spacers to get them over your brakes on r32/r33.
I need Rims that will fit with no spacers as I need a RWC. So if you can help there let me know
Geelong area.
$400.
shouldn't r34 gt-t rims fit without spacers on 32s and 33s?
Yes i agree they should. But they dont.
Just as you tighten the wheel nuts, the inside of the wheel just rubs the rotor
3mm spacers are all you need. But i though might aswell fill the gaurds as much as i could.
Oh Oh. Sorry, I just remembered . This only apply s to Spec M skylines. thanks to the bigger brakes.
Will fit base r32 gts-t , Probly r33 aswell.
Somone correct me if im wrong. =)
i just put r34 gt-t wheels onto my r32 gts-s. they dont fit they scrape the caliper about 1mm.
Thanks for clearing that up mate, Is this a M-spec.
I have heard people have taken 2mm off the inside of the caliper to make these fit.
yer jake i have seen so many people with these on 32's and 33's. I want to know the solution also.
Hey mate, was just chatting to ya bout wheels, but it wont let me PM anymore, im not 100% sure of offset on my rims, as it doesnt tell me, but they look to be about +38 on the 17x8's and +40 on the 17x8's, so they should be very similar to your previous Black wheels you were running on your r32.
Free bump too :)
I put 33 brakes on my 32 to clear my 34gtt wheels. Before that I ran 3mm spacers and they just cleared the 32 calipers.
The 33 calipers still run very close (< 1mm clearance) so maybe variations in manufacturing tolerances could explain why some 33s have problems with clearance.
i dont think its very safe to shave the caliper, its note the 'nissan' word that scraps. its the lower part of the piston. i put spacers on to give it a clearance. it scraps the wheel about 1mm or so without the spacer. the rears fit fine with about 10 - 12mm spacing
I have stock 34 rims on my '33... I could probably slide a piece of paper inbetween the inside of the wheel and the caliper... but certainly they are *barely* not touching. =-]
interested in swap for r33 gtr rims, powder coated (properly) in satin black.
Tyres and powder coat job are around 4month.
Cash adjustment my way as well lol
YESS!!! pm'd =)
well thats gay lol. i've seen so many 32s and 33 wit hthem on and i'm pretty sure they don't wear slip on spacers.
Hey Jake, what's my car doing in your avatar? Haha.
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
