I have 1 length of Titeflex Insulation Wrap. It's about 3600mm long relaxed. This is the stuff used on aircraft tubes for insulation and the quality is second none !
It has 2 stepped graduations so you can vary the thickness when applied. I've wrapped it around the tube of silastic to give you an idea of how it fits.
Condition: New & Unused
Price: $70 Delivered in Aus
https://www.sau.com.au/forums/topic/273373-titeflex-spiral-insulation-wrap/
length?
how does it stay in place?? does it need to be wire locked?
Sould cover a fair bit of stuff depending on how you use it ( single or double overlay ).
Best way to hold it in place is with those stainless steel straps that hold exhaust wrap on
but you can also use ~41 thou lockwire or cable ties.
:P I can't believe this is still for sale !
This is top shelf stuff and can only be purchased through GE Aircaft Engines in the USA ( AFAIK ) and you don't wanna know what it costs to buy a minimum amount + shipping !! :P
Since I got a couple of confused ( ? ) PM's I'll try to take some more pics to show how this suff can be used.
Yeah, just insulates what ever you wrap to keep heat in or out. It's just that you can vary the thickness of insulation depending on how you wrap it.
At the end of the day, it's no miracle product but it's very handy for certain jobs and very hard to come by.
Single wrap for medium insulation and tighter areas.
and Double wrap for heavy insulation and more open areas.
You would of course secure one end and pull the wrap tighter as you go along so it's ot as lose as in these pics.
Also, I would not recommend using it on an exhaust or anything that gets that hot.
    • yeah I have brown peeking out from in between some metal sheets close to the hood hinges. Strut towers look fine, even around the edges. some images https://imgur.com/a/brGt3Tu the one that looks the worst is the panel(s) going away right near the firewall on the passenger side, from underneath. Driver side does not look that bad.
    • I presume you are talking about a C34? Have you seen the buyers guide? https://www.sau.com.au/forums/topic/92065-buyers-guide-the-nissan-c34-stagea/ It's what got me to sign up to the forums when I bought mine. What kind of insight are you after? Up front I'd probably suggest to not get tempted by the poverty-spec models. I can't imagine a RB20DE to be engaging to drive in a 1600kg car.
    • yeah I try to be positive. Time will tell what becomes of it. Realistically my only other choice than to just deal with all the issues is to walk away and just sell it agai, at a loss.     I know a fair bit about these cars and knew before buying. I will try to deal with the rusty spots without tearing apart the metalwork for now. Sooner or later I probably will have to bite the bullet and do (or ge done) the arguably worst job an a 33/34 Skyline.
    • I'm aware that you can sink endless amounts of money into an engine. I don't want that kind of engie though. My power goal is 500, maybe 600hp at the max. I can get by with the nearly stock engine that I have now for that purpose and if it does need a rebuild at some point I would choose longer lasting components instead of the most ridiculously hp-rated ones. And do all the essentials of course.
