I have 1 length of Titeflex Insulation Wrap. It's about 3600mm long relaxed. This is the stuff used on aircraft tubes for insulation and the quality is second none !
It has 2 stepped graduations so you can vary the thickness when applied. I've wrapped it around the tube of silastic to give you an idea of how it fits.
Condition: New & Unused
Price: $70 Delivered in Aus
https://www.sau.com.au/forums/topic/273373-titeflex-spiral-insulation-wrap/
length?
how does it stay in place?? does it need to be wire locked?
Sould cover a fair bit of stuff depending on how you use it ( single or double overlay ).
Best way to hold it in place is with those stainless steel straps that hold exhaust wrap on
but you can also use ~41 thou lockwire or cable ties.
:P I can't believe this is still for sale !
This is top shelf stuff and can only be purchased through GE Aircaft Engines in the USA ( AFAIK ) and you don't wanna know what it costs to buy a minimum amount + shipping !! :P
Since I got a couple of confused ( ? ) PM's I'll try to take some more pics to show how this suff can be used.
Yeah, just insulates what ever you wrap to keep heat in or out. It's just that you can vary the thickness of insulation depending on how you wrap it.
At the end of the day, it's no miracle product but it's very handy for certain jobs and very hard to come by.
Single wrap for medium insulation and tighter areas.
and Double wrap for heavy insulation and more open areas.
You would of course secure one end and pull the wrap tighter as you go along so it's ot as lose as in these pics.
Also, I would not recommend using it on an exhaust or anything that gets that hot.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
