Hey guys, looks like my battery is dead. I'm just wondering what is the best way to get to it? When I was fitting my stereo in, I think its possible to get to it through the inside. Just by removing the back seat, undo that aluminium panel and thats it?
But I've been told to go through the boot, but that involves removing the trim and so on, seems like a harder task.
Can you access it from the back seat, or it it recommeneded to go through the boot?
Thanks!
https://www.sau.com.au/forums/topic/273429-r34-gtr-battery-removal/
Thanks!
For the aluminium panel.. have you tried removing it to have a look?
some have found it easier that way..... but through the back ...i think the strut brace needs to be removed to do so
^^^ that's why Bakes was running late to the 10th Anniv. joke-joke-
If you can get your car started just 1 more time, pack your deck chair and a drink, and take it to K-Mart (of course checking first if they've got the right battery), and let them instal it (Gold Exide with high CCA) for nothing. They also have a 'Memory Pack' to clip onto the leads, so that your electrics (eg clock/radio settings) stay intact.
Let them open the boot (after you've negotiated the battery price all-up), sit in your deck chair, point your finger at this-n-that and listen to them say "WTF".
I did however smash my knuckle into one of the brackets whenI was doing mine. Bled for 2 days and now I have a permanent lump on the bone of my knuckle. Safety First!! lol
smashes and scuff marks during DIY come with the territory ey.
mine was done through the boot, lots of things to remove.
Did it, charged up my battery and its good to go... so far!
Anyone know whether you can still buy the orignal batteries from Nissan?
is there any reason you want the original Battery?
charged it up? i would get a new one... it be embarrasing when the car wouldnt start in a crowded place
lol
can anyone recommend a battery that is roughly the same size as the standard nissan one? i bought one from battery world today and it is to big. I removed the original by taking out the strut brace and sliding it on its side. Dont really want to have to remove anything else, thanks
  • 2 months later...
Is the rear seat way possible at all? I need to remove my rear seats to do some wiring, and since my battery is living on it's last gasps now, if it can be done at the same time through the rear seat, that would be easier.
Is it just a matter of removing the seats and then you can remove the plate behind it to get to the battery?
Or is boot the way to go?
Thanks ;)
I managed to get it out but now I have the problem of finding a battery to replace it with.
I went to pick up a Century and got the correct one according to the product book but found that it's the incorrect size.
I did a bit more research and found the Exide site listed the LM51D as the correct size but it was still too big :woot:
What batteries have you guys used? And where have you bought it from?
I'm using a: MF40b20L Supercharge Gold 36 Series.
Not sure what is a "right" fit.
Its a tight fit, but does fit.
I got it from "Local Batteries"
but not sure if thats a aus wide franchise/company.
  • 1 month later...
Sorry to dig this up again.. I've tried so hard and gone through 3 batteries and had to refund them all.
It seems my positive lead is too short to be able to reach up on to the batteries listed above since they are a little bit taller than the current battery in there. Is there a way to extend that lead so that it can reach up?
Or any other advice you guys can give?
Thanks
Time to go to autosparks methinks, if you do not have the tools etc., to do the extension yourself. Autospark jonnies may also be able to put you on to the correct battery for your application, physical dimensions, L x W x H, correct CCA, terminal orientation & so on. At the end of the day the last thing you want is a dodgy hot joint on either of your battery leads in a confined/enclosed space. Could get nasty. For the sake of $100 saved short term?
My 2c
Cheers GW :P
Edit. PS: I love Battery World.
Edited by 260tech
  • 2 months later...
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
    • IIRC, it only cost me a couple of hundred dollars to get an Liverpool Exhaust to fabricate a custom stainless resonator for me to fit in the available realestate that I had under the car I actually watched as they did it, took about 1 hour to cut up the material, tig weld the body of it, and then add it to the exhaust  4"in and out, with a packed 5" body, that was about 12" long In the end, it is some blindly simple sheet metal work for an exhaust shop, and some welding
