Okay bout a week ago I had a 4 hour long phone call with Old mate Duncan and out stupid minds turned to Space frame Cars. After scouring through My105 we found a few interesting ones but nothing that fitted the bill.
So A little R32 GTS-T bare shell happened to fall into my lap last night and its now been decided that it will become a fully space framed R32.
Basicly we're (jay is being roped into the build) going to cut the entire floor pan and chassis out from under the shell and retain the original sills, A pillar, B pillar and part of the C pillar in accordance to the rules.
From whats left we'll build a comprehensive space frame chassis that will incorperate everything that needs to be there and nothing that doesn't
Engine wise we have to retain a max capacity of 6Litres, So a stroked RB33/26 is to be built. We've already got enough calipers and parts to build a car so there is really not much to purchase other than Chassis related rose joints etc etc. The Idea is to mount the block so that the 3rd cylinder is under the windscreen line. From previous cars and talking to a couple of well known suspension experts this is the best we're going to get with an inline 6. Obviously anything that needs to be fabricated to make it work will be done.
The body will be a composite Moulded shell based on an R32 GTR but I think it was 130mm wider each side Duncan and I decided.
There is a heap of discussion going on between several people about the way its going to happen but im open to suggestions from people about the best way to mould a body and so forth. Chassis work is no problem been there done that. Its the stuff we've not done before thats going to be interesting.
Here is the donor, kinda a shame to cut up a pretty straight shell but meh
https://www.sau.com.au/forums/topic/273508-skyline-space-frame/
  • Replies 245
Should be interesting.
Will be cutting the thing up in the next few weeks so will be sure to post up photos of what happens.
I think we've got alot of the bases covered besides actual suspension geometry the chassis is sorted design wise as is the body shell and components.
I've been looking at different designs to model the suspension off. Got a good idea which way were going to go with it.
Duncan your not getting outta this, it was your stupid idea that got put into my stupid head. Plasma cutter I rekon. Angle grinder makes too much noise for my neigbours precious ears.
Jay seen it this morning and his first sentence was What the f**k is that doing here!
Edited by Risking
Yeah rwd, hollinger and a quick change rear diff.
Already have everything running gear wise besides a tail shaft and engine.
We're building it to go play with the 6L chevy sports sedans at the local state rounds.
Edited by Risking
Yeah we have looked at that silvia. Someone should buy that thing its really well priced!
Its not exactly what I wanted and there is no real provision to fit an RB without cutting up the chassis.
Since we've got pretty much everything to build a car this way works out better in the long run.
Its a project more than anything so buying a car almost finished defeated the purpose of what I wanted to do.
When I built the white GTR I bought enough cage material to build 5 or 6 cages so we even have the material for the chassis.
Its an S13 if im not mistaken.
Doesnt really matter though cause not much of the S13 is really left.
The only R32 parts im using will be the door jams, A pillar, B pillar and bit of the C pillar. Roof will remain but thats bout it, No floor or chassis rails
Space framed race cars are basicly a chassis and rollcage with a fiberglass body over the top that resembles the car you want it to look like.
This is a space frame silvia that was mentioned earlier. Once the body shell is fitted it looks kinda like an S13 silvia.
Here is a pretty good ready about sports sedans in general
http://autospeed.com/cms/title_Anatomy-of-...80/article.html
Edited by Risking
    • Short answer: No. Medium answer: No, because you still need to conjure the things out of thin air to bolt them to a NA to make it a NA+T. Long Answer: No - The things you need to conjure - meaning a turbo, intercooling, manifolds, exhaust, intake/manifold/piping, clutch, injectors, fuel pump, AFM (?), ECU + Wiring (woo, N/A loom fun) have to come from somewhere. You could have many scavenged these things from an OEM car that someone had upgraded from and use some of these. This will be cost prohibitive now, especially so in the USA. You'd probably pay the same for newer, upgraded components that are better than old OEM stuff from 25-30 years ago. None of these big ticket items are re-usable for the N/A car. Why not buy new and upgrade while you're there? The only real consideration is turbo and fuel sizing and determining whether you want to stay within the bounds of the OEM engine or get into rebuild territory. These limits ARE lower with a N/A motor and especially N/A gearbox at the starting point. And if you're gonna upgrade those then you may as well consider having them built to begin with. Because everyone here knows you're never far from that next engine rebuild once you start making the power you want... The cars you see on the internet and SAU etc have been built over decades. If you're really clued in... you would sell your US car to somebody for what you paid for it. You would then scour AU JDM pages or SAU and buy a car like Dose's on this forum with your powerful American Dollar. This will save you so much money in the long term. Importing it could be tricky. Or it might not because USA. I have long said the only reason 90's Japanese stuff took off was because a) Japanese people had Japanese cars so that is what they used b) Australians could import these cars to Australia with very minimal changes and use them on the road here c) Neither country had well-priced access to US or EU Sports Cars. I don't believe the JDM scene would have taken off in Australia at all if we had EU priced EU BMW M offerings, or more especially the AUS V8 Scene would never have existed if we had the multitude of US cars like Camaros, Mustangs, Corvettes at the prices you folks do. After all - Do the math. I would say put a V8 in your R34 and that's the smart way forward. It is. I did it. I know this from my own experience. But at that point there's no reason to simply not buy a C5 or C6? It would be simpler and easier and cheaper and bette-
    • Reading all this... hurts lol. I have an ENR34 5MT and I paid an inflated USA price for the car alone, had to do tons of preventative maintenance past that, and so I'm over $30K USD into the car already and haven't even touched power.  I wanted to +t it. Not even trying to make GTR numbers, I'd be happy with 250hp.  Can I get away with paying much less to make that happen?
    • Damn you’ve done well, definitely snapping necks.
    • Great weekend and event. Open fire at the caravan park, perfect weather all day and a great feed and a couple of drinks at at awesome country pub.
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
