  • Replies 245
ok i am just about to have our guys do a wide body kit for my GTR, i was thinking that i might get them to do an entire front so it can be lifted off in one piece.
That and the doors should make quite a difference, i will see how it progresses as only a few days until the GTSR arrives and that will be # 1 priority for a few weeks so might not get it done for a month or so. We are set up for carbon fibre too but lets see how it turns out, how much wider are you going to run the car?
haha group buy then...I'll take a set for our sports sedan too :P Local regs allow up to 100mm wider, and I assume Brad is using GTR dimensions as a base (ie it will be log booked as a gtr not gtst for the extra base width).
Mine will be 100mm per side larger than a GTR. It will resemble a skyline but wont follow the same body lines.
It will have a GT car style front with the tires sitting well up inside the guards and so forth.
A normal wide body wont cut it due to the ride height.
Chassis rails are 55mm off the ground so you can imagine the bulk the guards are going to need to cover the tires.
Ill put some recent photos up tonight. I now have alot of the chassis done. Just need to do better front legs as im not happy with the ones I have and then can finish the main part of the cage.
yeah from the rear
Floor will be within the guidlines
Flat under the car except bwteen the wheels as per the regs.
Ive decided to lower the budget on this car and probably put it up for sale when its finished and competative.
Or ill donate it to Jay to drive and ill remain the owner, I dunno something will happen with it.
Already there is things I want to do differntly so ill be building another once this is complete.
I really want to do an inboard suspesnion set-up and change the control arm layouts around but now the main chassis is done its to hard to do so ill save the ideas for next time around
Edited by Risking
fear not Duncan i didnt sell it and we have a new style haltec ECU they want tested for bugs so she will live again. and we have 7 guys working on bloody cars these days lol so she will still get her dose of lovin even if its someone else lol.
I will send you some pics of the current body kits under development, We have an EVO kit now that is what you looking for Brad its now over 180mm wider and sits 35mm off the ground with a full flat bottom, wind splitter, rear difuser etcetc. For the time attack car we are building. Not all that bid a deal i wouldnt think to do the same with the skyline.
Is the car 35mm off the deck or just the body kit??
My actual chassis rails are 55mm off the black stuff. so the body of the car will actually have to sit alomost level with the chassis rails. Min 40mm rule sucks
It'll be fun to get onto the trailer with that kind of ride height but meh.
I dont think it would be possible to get a skyline that close to the ground without doing some major re working of the suspension. I know Johns Z car is no where near that low and I dont know about marks R34 but I suspec alot of that is body kit hanging down
Edited by Risking
Duncan can you email me the current rules again,
I seem to have lost them and google is not working for me.
I can widen it 100mm per side yeah?? Ive had a bad feeling its 100mm total but im sure thats wrong!
And on a side note the other GTR got a new gear box yesterday.
We pulled the old one down its got a shattered 3rd/4th selector fork. Its absolutly smashed to bits.
Edited by Risking
im not sure how it will be done yet,
the current car has 4m long ramps and is 80mm off the ground. it JUST get up onto the trailer deck.
Im going to have to get a new trailer to take the width so I may have to custom build it and make the trailer lower to the ground as well.
massive thanks has to go out to peter at Bonds roll bars for his help today.
I was having a few problems getting front legs that would work with the chassis design and didnt have the time or patience atm to bend them up. They could not be too tight to the a pillar due to the body shell needing to be removable but they had to be a neat enough fit to look okay and do the job.
Peter came to the rescue and made me up a set of perfect fitting legs this morning. They are close enough to the pillar to tag neatly but far enough away to make shell removal easy and possible.
    • The exhaust gases are at their highest temperature as they leave the exhaust port and enter the manifold. They cool as they flow through the manifold because they transfer heat to the manifold and the manifold loses heat to the surrounding environment. Thus, inevitably, the exhaust gases are cooler as they enter the turbo compared to when they entered the exhaust manifold. So, yes, the exhaust manifold can easily get as hot as the turbine housing. Having said that, you will generally see the highest temperatures where the exhaust gases have to slow down or they are concentrated into one area - which is usually the collector on the manifold and in the turbine housing, because the gases slam into the metal at those places, increasing the convective heat transfer coefficient and transferring even more heat to the metal than they might just flowing past elsewhere. Exhaust manifold heat shields are a good idea - certainly for the stock manifold they are there from the factory. People seldom have anything like that on a tubular manifold because they are hard to achieve. Some might wrap a tube manifold with fibreglass tape - but this has a reputation of leading to cracked welds. The best case is generally to put ceramic coating onto the manifold to prevent it getting as hot (internal coating) and radiating/convecting heat into the bay (external coating). All the real heat from a turbo comes from the exhaust side. The gases entering are at ~800-900°C and the steel/iron gets nearly that hot. The compressor side is only going to heat the charge air up to <<200°C (typically not much more than 100°C). So that's nothing, by comparison. The compressor is not a significant source of engine bay heat.
    • Late to the party, specifically joined this forum as I just bought one of these and this thread has been a gold mine of info. If the OP is still around, mind if I ask what gas you been putting in yours? Mine has a Japanese sticker in the cap saying premium but it seems to get way worse mileage on premium (95) than 91. I always thought it was meant to be the other way round🤷 I do think Nissans claimed "6l/100km" is a bit fantastical 😂
    • Does exhaust manifold get hot as turno exhuast side? I have a turbo cover to managr heat in the engine bay but  nothing is covering the exhaust manifold before turbo   i know as turbo does compress air, the temp does go up however does that mean exhaust manifold would be as hot?
    • It's excellent but I'm still breaking it in so I'm not 100% sure where it'll end up. I would say it's about 15% heavier than stock and the smoothness of the slip zone is quite progressive but you need to be a little patient compared to stock or it'll bite hard and stall. Stock I got away with absolutely horrid clutch control. Like I said before I couldn't even tell where the clutch would grab when it was stock so releasing way too quickly without enough revs it would just slip and the revs would drop lower than ideal but that would be the end of it. Currently there's a bit of a nasty clutch judder if I don't apply enough revs + find the exact wrong point of the slip point in the clutch pedal but it feels like it's slowly resolving as I drive it more. I would not recommend the competition clutch unless you really need the extra clamp force. I think this clutch combined with the Nismo operating cylinder is going to be exactly what I want. Enough bite that you need to remember the release point to avoid stalling or rough shifts, but progressive enough that it's not hard to drive by any means and not heavy at all. I tried a "super single" clutch on my friend's 997.2 Turbo 6MT and that was absolutely horrid. It runs an electrohydraulic power steering pump for the clutch power boost so there's zero feedback in the clutch pedal and there was a horrific clutch shudder well after break-in due to the lack of marcel springs or hub springs in the friction disk. It felt like the slip zone was the thickness of a single toe twitch as well so it was almost impossible to avoid stalling it unless you gave it a ton of revs and just dumped the clutch instead of trying to be smooth with it. I was terrified of pulling out in front of traffic. I have also tried some kind of "super single" on an EK9 and that makes this twin plate Coppermix look like a stock clutch. Releasing the clutch pedal even slightly too quickly feels like you're getting rear-ended. The pedal is extremely heavy as well and there's no vacuum assist like the GTR.
    • Yeah, well I was probably way underguessing the $300 figure anyway. Just multiplied a "normal" by 4 for the purposes of pointing out it's not cheap, particularly if it has to be repeated.
