  • Replies 245
Great build up risking, that thing is gonna be mean once it's done! Not sure if this will help but I came accross this thread on gtr.co.uk and thought it you could use it for tips or hints or whatever as this guy is building a space frame r32 aswell, and there's always more than one way to skin a cat. It's a good read :merli:
http://www.gtr.co.uk/forum/74968-neverending-project-x.html
Cheers, Mat.
That one on GTR.uk is a bit odd.
His gone to some extreme lengths and its still based on a floor pan chassis. He may as well have thrown it away and started with a proper space frame like i have.
The way his cut out the firewall and floor section is not really right.
Its a good bit of gear by the looks of it but id have done it properly with a full space frame chassis.
slight update,
Jay and I looked over engine locations today,
God damn its not going to be easy. The tail shaft will only be 12 inchs long if that and the dry sump pump etc is going to have to swing off the other side of the engine now. Due to the engine being mounted so far back and offset to the pass side nothing will be simple.
Its going to have to go in through the windscreen opening as the intrusion bars etc all get in the way and the floor will have a X in it so no entry there.
Small incidental things are going to become a real nightmare soon. intercooler, radiator, diff coolers etc etc
the space is more than ample its the ammount of shit I have in there thats the problem!
Im looking to swap the cars around in the next few days and take it to somewhere bigger.
Its almost time to try and mount an RB26 into a hole thats way to small.
yeah about that,,,,,,
Its a little tight but very do able. Im working on it a little slower than normal with bostons car here as well but got a few things done last night.
Ive now got the fuel system sorted as well. and a new dry sump tank.
Im considereing making it left hand drive too, but not sure as yet,
Short shafts are okay besides the uni joint angles.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
