My 20 cents;
Your oil temp gauge isn't working properly, refer Duncan's comments above, so fix or replace is the answer.
I have never seen the need for an oil cooler thermostat in Australia, it quite simply doesn't get cold enough in all but a couple of places.
Overfilling the sump is related to oil surge, but the real reason for it is to compensate for the oil that stays in the cam covers when high rpm is used for sustained periods.
The fluctuations you see in oil pressure could be oil starvation around the pick up as so much is trapped in the cam covers, they hold well over 2 litres.
The larger the diameter of the restrictor hole the more oil goes up to the cam covers, a higher flow oil pump just makes that situation worse.
I assume that it has the standard GTR one oil feed to the head blocked off and it has a Tomei restrictor in the other. I have seen RB26's with 2 restictors, which is not correct.
The standard poor oil returtn to the sump is a well know RB problem, that's why the serious track guys run external oil returns and enlarged oil return passages to the sump. Or dry sump with a scavenge stage for the cam covers.
The one way doors stop the oil from flowing to the dip stick, that's why you can't check the oil level immediately after shutting down the engine. So don't let it worry you.
Maybe 25 cents worth.
Cheers
Gary
Hi all,
Right I found out whats going on! It's what I thought with a slightly different twist.
Basically the oil isn't getting up to temperature, therefore it takes a huge amount of time for the oil to drain past the baffles back to the area where the dipstick goes in the sump.
This makes it looks like there is no oil after starting. I'm looking into getting a oil thermostat or maybe using something like a 5w40 instead of the 10w50 to help the oil get up to temp quicker. At present I have to sit for over 30mins at 2k to get the oil to 60 degrees! Once it's up it stays up but if you don't do this it will never get up to temp, I guess due to overcooling?
Also the oil cooler is a laminova unit, does anyone know if you can get thermostats for them?
Cheers for all your time.
M
do not sit still idling or revving the engine to get things to 60 degrees. that is the worst way to do things. your oil will get up to temp much quicker just by normal driving where the engine is under load etc. not to mention the impracticality of sitting in your garage for half an hour revving your engine! start the car and you should be driving off after no more than 30 seconds. get a new proper temp guage. you should need no more than 5 mins (10 max) of sedate driving to get things up to around 70-80 degrees C. sitting in the garage waiting for things to warm up is just wearing out your engine. you want it to get to operating temp as quick as possible and the way to do that is sensible driving (ie revs under 4500, no WOT, not big boost etc).
Thanks for the detailed replies everyone.
What I'm doing now is running 0.5l extra which helps reduce the oil pressure drop when accelerating in low gears. I'm running relocated filter, oil cooler, tomei baffles and N1 pump. I guess without running the extra oil it can't return to the sump quick enough. Even if I leave the car after a long run for 45 minutes plus it still barely registers on the dipstick. I know Sydneykid mentioned it would take a while for it to drain back to the dipstick area, but if it's showing little oil in the sump isn't it wise to add a little more?
Now that I run 0.5l more, when I turn the car off when hot and check after a short while the level is 100% to the max. I basically topped it up when warm until it went to the max. When I check when cold it's up at the start of the bend, when I check when warm it's at the max line. Oil pressure drop has also been reduced.
I will also look at replacing the Greddy gauge or at least find out what needs replacing. Will also make sure I don't warm up idling now I know that the gauge is buggered!
Cheers all this is a top forum!
M
Edited by Monky
  • 1 month later...
Hi people,
I have the same set up in my GTR, tomei baffle, restrictor etc etc
what gave me the shits the other day is when I fitted my Defi gauge kit and noted my oil pressure disappear when you give the throttle a quick dab in 1st or 2nd!!!!!! yet the factory gauge just sits there at 3.5bar and doesn't even move.
This thread has been very interesting to say the least!
I will be filling my sump with the extra half a liter tomorrow and see if this improves....
cheers,
Mike
M
Edited by The Alchemist
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
