not sure if i still need this
d/c the o2 sensor as recomended by a mech mate and the idle is smoother so it could be a dud o2
will keep it posted
problem is just a flat spot as the car is coming onto boost, not plugs or coilpacks and not grounding either
https://www.sau.com.au/forums/topic/273574-want-to-borrow/#findComment-4642431
I have igniter and afm that ur welcome to try but am down south
cool thanks for that
bit busy with uni atm but if i get a chance i'll try to get there
can you let me know if your up launnie way with spare time please?
https://www.sau.com.au/forums/topic/273574-want-to-borrow/#findComment-4644319
Wont be up your way anytime soon m8 but i can post it up to you if your desperate :P
https://www.sau.com.au/forums/topic/273574-want-to-borrow/#findComment-4644474
na i think i have narrowed it down to a bad o2 sensor
unplugged it and reset the ecu and it drives and idles much better
plugged it back in and it went crap again
where would be best to get one from? i'll prob use the el ford falcon one and cut and splice
repco? bursons? or other?
https://www.sau.com.au/forums/topic/273574-want-to-borrow/#findComment-4644653
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
