I recently picked up an R33 S2 not running as a project car and am selling off some of the parts i have upgraded. Parts are located In adelaide in the modbury area, I will post at buyers expense.
Front and Rear brake rotors $80
Didnt feel warped but the lines were full of air and moisture from not being driven in so long, id still machine them any way.
The rear pads were ferodos have heaps of meat ill throw them into if you want them or there going in the bin.
Stock side mount Intercooler $20
Few bent fins, Made 182rwk on dyno.
Turbo Smart Dual Stage Boost Controller $50
Doesnt look very old
Sony CD player with remote $50
getting a double din piece of carbon fibre made up and would rather listen to the turbo spool.
Top and Bottom radiator hoses light blue in colour $40
Got these put on when i got my head done at the work shop, i was told they were dark blue but there light blue instead, Doesnt match my silicon hose, or intercooler silicon joins
Practically new driven no more than 50km i paid $85.
Autoguage Boost Guage with fake carbon fibre A pillar pod
I found this coiled up under the drivers side dash, dont know if it works or not $Offers
Also have S2 Rear Garnish in wine red coulor bit faded, $40
post-60037-1244332821_thumb.jpg post-60037-1244332946_thumb.jpg post-60037-1244333122_thumb.jpg post-60037-1244333286_thumb.jpg post-60037-1244333442_thumb.jpg post-60037-1244333668_thumb.jpg
Will Swap parts if some one has a RB20DET ECU they wana get rid of.
Any questions PM me, all PMs will be replied to after 5pm as i start work early and do long days.
:) g'day. mate! do u have a bootlid release cable? i need it.
plz message for me. 0450484777
have a Nice day!
  • 3 weeks later...
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
