well if u want to go in the GB i can do a full refund (paypal refunds fees also), might take 3-5 days to go back on CC, and u can get it later in group buy (probably start next month i imagine), or i can continue with it as normal and send it out by monday
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4654291
Hey all, just thought id add my bit;
I bought an Ecutalk cable of ebay for$60 and bought an adapter cable (also of ebay) to convert it to usb for $5, the converter cable was 1,5 meters long so when connected, the laptop can sit comfortably on the passenger seat. For me it was cheaper and I got a longer length than buying the Usb version cable.
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4656060
if u buy a serial ecutalk cable on ebay, before u pay send a message, say u want a usb/serial and one can be sent for extra $5 added to invoice. its the 'a111 usb serial' as mentioned in item description, 3foot long roughly.
the only issue with usb/serial converters is some of them dont work reliably (and FTDI based ones, which is the chip used in the usb cable, are expensive).
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4656166
is impul a daughterboard (still using stock ecu)?
as you paid with echeque itll take a few days to clear
http://www.filedump.net/cameronbnr/For_Sale/impulecu.jpg
-Overview-
- Better air fuel ratios
- Ups the boost a little
- Takes out speed cut
- Increases rev limit to 9000rpm
- Tweaked fuel maps so you can run more boost safely
- Plugs straight in, no other modifications required
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4659792
Just read this.
Impul is just rechipped Nissan ECU even with Nissan part number for the tune...
Read out the image using EPROM programmer or consult and then that can be modified. As mentioned above either Dr Drift or a tuner with Nistune can do this for you... and use that as a base tune to work from
Those chips are soldered in so you will still need to get ECU resocketed
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4659803
yep, assuming the consult code is still intact (in theory its possible to modify a rom to stop consult working, e.g. to protect someone from downloading your rom). fortunately i havent heard of any daughterboards/remaps etc losing consult capabilities (if anything only rom reading support, but even then most commerical tunes i dont remember hearing they disabled rom read).
so should be all good
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4659827
I reckon I might get a V2 display & permanently mount it in the car.
:P
***edit***
Just bought one...
I picked up my new display unit from the post office today, plugged it in to the RSFV, configured the engine parameters for the trip meter and hey presto, I can now see how much fuel I'm burning :)
And as an aside, it shows all the ECU data just fine :)
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4662897
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
    • Nissan needs to forget about building SUVs in every size possible and bring back the damn Silvia/200sx duo to compete with the 86/brz. Maybe with the Honda type r motor pointing the right way
    • Good to see you followed your heart, got your dream car and have it pretty well sorted out now. I think anyone can get caught out with a seller not being 100% honest about a cars problems. Can relate to all the electrical issues, had similar issues with my first car (mk2 escort) ages ago
    • I just bought the Nexus S3 for my gtt, haven’t installed it yet as I’m collecting parts to do everything at once…so far spent $14,000 The Nexus is nearly future proof
