well if u want to go in the GB i can do a full refund (paypal refunds fees also), might take 3-5 days to go back on CC, and u can get it later in group buy (probably start next month i imagine), or i can continue with it as normal and send it out by monday
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4654291
Hey all, just thought id add my bit;
I bought an Ecutalk cable of ebay for$60 and bought an adapter cable (also of ebay) to convert it to usb for $5, the converter cable was 1,5 meters long so when connected, the laptop can sit comfortably on the passenger seat. For me it was cheaper and I got a longer length than buying the Usb version cable.
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4656060
if u buy a serial ecutalk cable on ebay, before u pay send a message, say u want a usb/serial and one can be sent for extra $5 added to invoice. its the 'a111 usb serial' as mentioned in item description, 3foot long roughly.
the only issue with usb/serial converters is some of them dont work reliably (and FTDI based ones, which is the chip used in the usb cable, are expensive).
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4656166
is impul a daughterboard (still using stock ecu)?
as you paid with echeque itll take a few days to clear
http://www.filedump.net/cameronbnr/For_Sale/impulecu.jpg
-Overview-
- Better air fuel ratios
- Ups the boost a little
- Takes out speed cut
- Increases rev limit to 9000rpm
- Tweaked fuel maps so you can run more boost safely
- Plugs straight in, no other modifications required
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4659792
Just read this.
Impul is just rechipped Nissan ECU even with Nissan part number for the tune...
Read out the image using EPROM programmer or consult and then that can be modified. As mentioned above either Dr Drift or a tuner with Nistune can do this for you... and use that as a base tune to work from
Those chips are soldered in so you will still need to get ECU resocketed
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4659803
yep, assuming the consult code is still intact (in theory its possible to modify a rom to stop consult working, e.g. to protect someone from downloading your rom). fortunately i havent heard of any daughterboards/remaps etc losing consult capabilities (if anything only rom reading support, but even then most commerical tunes i dont remember hearing they disabled rom read).
so should be all good
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4659827
I reckon I might get a V2 display & permanently mount it in the car.
:P
***edit***
Just bought one...
I picked up my new display unit from the post office today, plugged it in to the RSFV, configured the engine parameters for the trip meter and hey presto, I can now see how much fuel I'm burning :)
And as an aside, it shows all the ECU data just fine :)
https://www.sau.com.au/forums/topic/273589-ecutalk/page/2/#findComment-4662897
    • They're supposed to not be compatible.
    • Evening fam, Pretty much what the title asks, I have looked all over and can’t find a proper answer expect one post from almost a decade ago which is vague. ive seen photos and they look pretty much identical, would an r33 GTR N1 reo work on an r32? reason I ask is they are cheaper to buy… $700 compared to 1k+ for an r32 n1 reo
    • Couldn't help myself, had to start putting it together.... It really is a solid bit of kit.  Probably stronger than i would have made it myself to be fair! 🤣🤣 Sweating like a pig after that.  Bloody hot and muggy day today, time for a swim now!
    • Yeah was thinking that. I've had the car go lower idle possibly around 650rpm every once in a long time after pouring fuel and would sound quite rough like a misfire, almost like it's shit fuel or something but who knows.
    • @Wazmond you are correct, my bad, was not my intent    https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.    I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.    I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.    https://gtrfestival.com.au
