  • Replies 112
Posted Images
you need an app to work that out? :)
here's what you do, every time you fill up make sure you reset your odometer to zero. Next time you fill up, say 50L, just add 2x 00's to the end of it, so 5000. Divide that by whatever your odometer says and that's your L/100k's.
21.2 litres per hundred is the correct figure. NOw I've only done around town driving and no highway and I reckon maybe 15% of the time I have given it a squirt, but still!
I would have expected about 16 litres per hundred. I think something must be wrong, either O2 sensor or bad tune (too rich?) anyway to roughly tell or should I just book it in?
77,000 km's on the clock BTW so perhaps an O2?
I would do another tank full and do the calculation on the back of an envelope. I have got my S1 down to 20L per 100km by giving it heaps on short trips but M35s are supposed to be more economical. Your figure is too bad to be just the o2 sensor. I would do another trial before spending any money on it.
Based on a supposedly 80L that the M35's have, that means it can only do about 380kms on a tank. Unless you're flooring it everywhere, that really cant be right. My one can do at least 500kms on a tank in the city and over 700kms on freeway.
What does your computer say?
The car display says: The best the display 7km's/litre and 450 km range.
7km/L is 14.28liters per 100km.
So if you are using 20 liters per 100km your display will be 5km/L.
If this is right, it is terrible. And you live in a flat city. Try Sydney will all the hills around the coast and I still manage 7km/L.
I think it is time for a check up.
Cheers
Andy
Doesn't sound quiet right, they are definatly fuel chewers but not quiet that bad.
This is part of the reason I'm looking into the ECU retune (remap) option as I'm just burning too much fuel, mind you I tend to drive in manual shift all the time and I'm not always gentle on the pedal :thumbsup:
Has your car had any mods you don't know about maybe? I assume the turbo is standard or has it been high-flowed? Jetwreck (Craig) was talking some pretty shocking figures last night at the meet in reference to his high-flow. He said he gave the pedal a good workout and his fuel economy dropped to 1.5L - 2L to a KM or something like that lol.
How hard does your car pull in manual shift mode under full boost?
I have the exhaust, a BOV and the Apexi airpod, don't know about anything else at this stage, will find out when I take it to the guys at Trojan for a service.
I would need to drive in someone elses Stag to compare becuase I had never even sat in one before I bought mine sight unseeen :thumbsup:.
It goes like the frakin clappers though, manual or auto :(.
It goes like the frakin clappers though, manual or auto :thumbsup: .
Maybe it's got some extra's you don't know about, the add-ons you know about may give it a little more pulling power but you never know what other hidden goodies you might have :(
I'll have to drive up and have a squiz :)
What are you doing later this week?
i'd like to know what i can do for fuel at the moment too,
seem to get close to 500km's per tank, but have never put 80L in it full yet. usually close to 70.. dont know how far i can push it untill i run out..
Is there an o2 sensor i can change? will it even improve anything?
still going to hunt for an ecu for sure tho! it seems like a good option, i will get my wideband o2 on the car today and see what it goes like.
Hey if you're picking it up who gets to F*@k? :)
I don't want to know, but just do it quietly whoever it is! :bunny:
Yeah, I think you better go pick it up yourself Iain, I'm not getting caught in no triangle!
Cheers
Andy
You really shouldn't be getting more than 15L/100km unless you're like redlining it everywhere...
I drive about 15 mins each way to work each day and I get about 14.5L/100km due to the short trips. If I do a few longer weekend drives in there that drops to around 11-12L/100km because it loves the open road when you hold it in 5th gear.
But the short trips to work really mess up the fuel economy.
I'd aim for around 14L/100km (ie. around 500km on 70L) - if you're not getting at least 15L/100km even in stop-start traffic, then I'd say there's a problem. But first I'd work it out manually (as others mentioned above) to make sure its not just your iphone app giving you dodgy numbers.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
