I dont think I can get more than 400km on a full tank in my M35 - I have only filled it twice since I got it, but it is chewing a hell of a lot more than my C34 stagea which was modified - My M35 is 100% stock!
Maybe I need a tune...
  • Replies 112
Posted Images
Just filled my tank for the first time, I never fill it but now I'm commuting :(
67.22L of 98 Vortex and the screen is telling me 545km @ 8.1KM/L.
Now I just have to control my right foot :D
The M35 should only use about 9.5-10L/100 on the highway. Anything over 10L/100km (or under 10km/L) on the highway means either something is not right or your right foot is heavy/shaky. Make sure to put the tiptronic into 5th when sitting on constant speed because otherwise the throttle is too sensitive and the torque converter will keep locking / unlocking, which will end up using more fuel. For some reason using the tiptronic makes it less sensitive and will keep the revs low and constant. :laugh:
The above is for a completely stock stagea. Depending on which performance mods you have it may do better / worse...
In my own experience, mine averaged 10.5-11L/100km on the highway when in D. Putting it in 5th using the gear lever gave me 9.8L/100km but I've seen lower than that since. I'll be doing another long interstate trip in about 5 weeks and reckon I should be able to beat 9.5L/100km this time.
Edited by pixel8r
WWATTTT ? 8.1 damn thats pretty high
did u just reset?
I reset a couple of days ago as I've been doing a lot of f3 driving and wanted to see how driving on the f3 was using mostly automatic mode, just slipping into manual shift for overtaking etc.
I'm hoping to be more like 10+km/L once the ECU is remapped.
Note that the M35 holds 10 more litres of fuel compared to older stageas, so 400km on a tank in a M35 is worse than 400km on a tank in a s1 or s2.
I'd say 430-500km would be a more accurate average for the M35, although it does vary quite a lot depending on where you live/drive etc.
I thought I would revive an old thread :down:
I done my regular commute from Blacktown to Tuggerah today and reset all the major efficiency and timing devices on the screen.
Here are the stats for my trip:
GAS ETA, i like it! :P
But atleast I've posted up some stats, will be interesting to see my stats after the remap in it's current configuration.
It should be putting out more power and using less fuel, can't go wrong!! :P
Once we know the remapping works and is beneficial it will be time to get a turbo to GCG for a high-flow rebuild and supply the new turbo with the dump pipe to Envy Imports for change over.
I'm excited, I've also asked Envy Imports for a quotation to supply and fit a FMIC with 3" plumbing.
The ECU should arrive from Brisbane about Tuesday, I should have paid the extra and had it sent from Japan early last week lol
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
