I dont think I can get more than 400km on a full tank in my M35 - I have only filled it twice since I got it, but it is chewing a hell of a lot more than my C34 stagea which was modified - My M35 is 100% stock!
Maybe I need a tune...
  • Replies 112
Posted Images
Just filled my tank for the first time, I never fill it but now I'm commuting :(
67.22L of 98 Vortex and the screen is telling me 545km @ 8.1KM/L.
Now I just have to control my right foot :D
The M35 should only use about 9.5-10L/100 on the highway. Anything over 10L/100km (or under 10km/L) on the highway means either something is not right or your right foot is heavy/shaky. Make sure to put the tiptronic into 5th when sitting on constant speed because otherwise the throttle is too sensitive and the torque converter will keep locking / unlocking, which will end up using more fuel. For some reason using the tiptronic makes it less sensitive and will keep the revs low and constant. :laugh:
The above is for a completely stock stagea. Depending on which performance mods you have it may do better / worse...
In my own experience, mine averaged 10.5-11L/100km on the highway when in D. Putting it in 5th using the gear lever gave me 9.8L/100km but I've seen lower than that since. I'll be doing another long interstate trip in about 5 weeks and reckon I should be able to beat 9.5L/100km this time.
Edited by pixel8r
WWATTTT ? 8.1 damn thats pretty high
did u just reset?
I reset a couple of days ago as I've been doing a lot of f3 driving and wanted to see how driving on the f3 was using mostly automatic mode, just slipping into manual shift for overtaking etc.
I'm hoping to be more like 10+km/L once the ECU is remapped.
Note that the M35 holds 10 more litres of fuel compared to older stageas, so 400km on a tank in a M35 is worse than 400km on a tank in a s1 or s2.
I'd say 430-500km would be a more accurate average for the M35, although it does vary quite a lot depending on where you live/drive etc.
I thought I would revive an old thread :down:
I done my regular commute from Blacktown to Tuggerah today and reset all the major efficiency and timing devices on the screen.
Here are the stats for my trip:
GAS ETA, i like it! :P
But atleast I've posted up some stats, will be interesting to see my stats after the remap in it's current configuration.
It should be putting out more power and using less fuel, can't go wrong!! :P
Once we know the remapping works and is beneficial it will be time to get a turbo to GCG for a high-flow rebuild and supply the new turbo with the dump pipe to Envy Imports for change over.
I'm excited, I've also asked Envy Imports for a quotation to supply and fit a FMIC with 3" plumbing.
The ECU should arrive from Brisbane about Tuesday, I should have paid the extra and had it sent from Japan early last week lol
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
