There is a big difference between R32s and R33s, dont just make ur mind up on their prices. They cost about the same anyway.
I think it is a resonable price, should be able to get it for $18k. If u are going to buy a car from a dealer it definately pays to get a check done, i had 2 done on 2 different cars before deciding on my new r32 and they were worth every cent. Looking back now if i had bought either of the 2 cars i got tested i would have been ripped off.
The extra cost is worth it if u get a warrenty, but make sure u read the conditions and that its valid before u buy the car.
My car came with 1 year warrenty, but when I looked into it after i bought the car it had to be serviced at intervals less than 5000kms to keep the warrenty . It had done 6500kms since last service, when i rang the warrenty company they said tough luck.
Negotiations continue,...
I now have extented rego, and reduced stamp duty,
The Dealer has also agreed to pay my deposit back if the car is not to my satisfaction when i pick it up, which will be the 8th of November.
Hopefully the the inspection and sale goes well.
Cheers for all the help and advice guys, i have appreciated it alot.
***** THIS THREAD WILL SELF DESTRUCT IN 5 SECONDS *****
.............. *cough* *cough*..............
"Mitchyr32 that was ****ing sad !!!"
(wait a minute, did i just refer to myself in the 3rd person?)
mate that's very pricey
to give you an idea i got mine in late jan (ok i know it was before sevs) through private sale here in melb:
- 93000 kms genuine
- original dark blue paint
- R32 GTSt
- auto (the main reason for cheap)
- no side skirts or stereo or spoiler
- R33 rims
- body in good nick although was keyed on one side
i paid $11,500 as they guy was heading overseas and depserate to sell and i pretended that i wanted to wait before buying (he he)
moral of the stor: that car is way overpriced and you should be looking at something much cheaper if you really want a good buy. just because it costs more doesn't mean its better...
...BUT...
the choice of an R32 was a great one and if you do get one you won't be disappointed! handles SUPERB and accelerates well.
its a bit slow off boost but once the turbo spools up it gets some real kick.
...and try to see if the one your looking at is an M-spec (has some extra features of which the 4-pot front brakes is the most imporant)
cheers,
Warren.
i paid $18,000 for mine about 2mths ago and it is stock with a nice set of wheels. I paid the extra because i would rather get a good example rather than one with afew mods that has been cained around a drift track over there.
If you do this then you also have the fun of modding it any way you want and knowing the mods have been done to a high quality (i also enjoy working on my car).
that is my opinion anyway.
if you get it i hope you enjoy, otherwise good luck in hunting down another one.
i paid about 13 200 for mine all up on road. That is a near stock manual m spec, with alarm, stereo, boost controller, turbo timer. Look around mate, go for the private sale I rekon, you can get the same for a lot cheaper, or for the same price one that has a bit done to it and in good condition.
Also, If you have that much to play with, have a look around for a 33 or a 200 sx - but y would ya, skylines are better :)
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
