hi
previously when i tested my friends boost gauge i tap it where the actuator is and reads 10 - 11psi this was 1 month ago
now when i installed mine (yesterday) in and tap it from the intake manifold (where the stock gauge gets its reading) i get 7psi at full boost
car is using r32 actuator so i know it should be getting 10psi
so is my actuator stuffed or is something else or it meant to belike that?
Edited by NARTRI
https://www.sau.com.au/forums/topic/273631-boost-reading/
when you are hitting 7psi.. what is the stock gauge reading?
if the stock gauge is the same then it's more likely your actuator isn't working properly, but if the stock gauge is hitting about 10psi or thereabouts it may just be the new gauge install.
does the car run any differently? without looking at the gauges does it feel like it used to?
https://www.sau.com.au/forums/topic/273631-boost-reading/#findComment-4641957
So your saying you have a VAC hose going from the Actuator to the stock boost gauge tap on the IM?
I think thats way to long. Plumb the actuator up to where the stock actuator plumbs in and it will work. Dont forget to remove the boost solenoid too.
Take the solenoid out, plug the nipple on the intake, and run one line to the actuator. Whallah. 10psi
https://www.sau.com.au/forums/topic/273631-boost-reading/#findComment-4642624
the solenoid have being taken out and plugged the nipple on the intake when i installed the actuator in
no no no everything is where it meant to be i didnt reroute the hose at all
the first test the aftermarket boost gauge line was tapped to the actuator and the second test was tapped to the IM
guess im gonna tap it again to the actuator and see how that goes see which is faulty
https://www.sau.com.au/forums/topic/273631-boost-reading/#findComment-4642635
You will get a pressure drop throughout your intake system. ie pressure in plenum will be lower than at the outlet of compressor. How big the drop is depends on a quite a few things...btw a drop from 10 to 7psi is pretty poor....
The implication of this is that with a fixed WG actuator, the boost pressure at the plenum will change depending on where the feedback for the actuator is taken..ie whether it is taken from the plenum, intake pipework or directly after the compressor...
https://www.sau.com.au/forums/topic/273631-boost-reading/#findComment-4642698
Sorry i didnt read the post properly, didnt realize you were talking about gauges!
I plumbed my Apexi gauge into the Vac line to the FPR, so essentially the same place (manifold), and it reads 10psi perfect.
Maybe there is a problem with the gauge? Tried testing it with someone elses?
Reason i say this is because its a bit easier than changing actuators :thumbsup:
That, or someone sold you an R33 actuator. They are 7psi. Could be possible..
https://www.sau.com.au/forums/topic/273631-boost-reading/#findComment-4642957
thats cool gotRICE
i wont be able to do some testing till the weekend which kinda ticks me off a bit but oh well
na i know the actuator is off a r32 been using it for about a year now and had borrow a mates gauge to made sure
ill let everyone knows after the week is over dam i soo hate exams :)
Edited by NARTRI
https://www.sau.com.au/forums/topic/273631-boost-reading/#findComment-4643324
If its a r32 rb20 actuator it will definitely be running 9-10psi.
Back when I ran the rb20, stock turbo and stock exhaust with compliance cat it was running 9psi. Full 3" boost rose to 11-12psi.
Hows the cat?
All though unlikely IMO checked for boost leaks?
Edited by SLAPS
https://www.sau.com.au/forums/topic/273631-boost-reading/#findComment-4643742
Just for interest sake, the following is a good way of testing the accuracy of a boost gauges is as follows.
Go to the chemist and ask for a 15 or 20mL syringe. Even larger ones are fine. The bigger the syringe the harder you have to push the plunger. The syringe is plumbed up to the boost gauge and when you press the plunger the boost gauge will register what pressure is in the syringe.
To check the calibration there are three ways:
1. If you have a gauge that you know is accurate, plumb this gauge up with the other gauge and then to the syringe all at the same time. They will see exactly the same pressure as each other so you can compare the two readings.
2. If you don't have another good gauge, you can calculate the pressure exerted by the syringe by doing the following. Measure very accurately the diameter of the bore od the syringe. Calculate the area. Measure the very accurately the force exterted on the plunger. This can be done by placing the syringe in vice and placing a weight of known mass on the syringe. Put some light oil (vegetable oil etc) in the syringe. Don't fill the syringe. The oil is just to reduce the friction of the plunger in the bore.
The pressure out of the syringe will be the 'force on the plunger' divided by the 'area of the plunger'. It is reasonably accurate. The main source of error is in the physical measurement of the area and force plus the friction of the rubber plunger on the bore. You will need to know a bit about physics to get the units right. If anyone is interested in doing this I can work it out for you...
3. Use a proper gauge calibration tool. Don't know how much these cost but they basically use the same principle as option 2 but are a lot more precise.
These methods beat trying to do road tests and are better for your licence.
https://www.sau.com.au/forums/topic/273631-boost-reading/#findComment-4646889
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
