THE QUIZ IS REGARDING THE MOTOR PROBLEM NOT WHY IT DIDN'T START IN THE FIRST PLACE CUZ THATS GOT EVERYONE FARKED
Well after a week of suicidal thoughts I have found that my situation wasn't quite what it was.
This is the saga ......................
- Dropped Skyline off at panel beaters after two days of little moves it stopped running NO NOT BATTERY
- Came down found fuel pump not priming although alarm controller battery was flat. Changed remote battery turned the alarm off and on but still wouldn't start.
- Had two different Auto Electricians check it out and couldn't fault the electrics but thought it was the computer as power was going in etc etc. Found for some reason all sensors throttle, injectors etc were not reading.
- Get it towed to nearby workshop HIPOWER RACING - They update the firmware on the Haltech E11V2, the computer and get all sensors back on. They keep kicking it over but it backfires etc and wont run.
GET CHARGED FOR TWO HOURS LABOUR BUT THEY CANT FIND THE PROBLEM
- Get it towed to Competition Tuning and Performance. They find that someone has moved the crank angle sensor(I KNOW WHO).
GET CHARGED FOUR HOURS LABOUR (JUSTIN LOOKED AFTER ME :) ) AND GET IT STARTED AND RUNNING. SOMEONE CUN7 HAD APPARENTLY CHANGED THE INJECTOR OHMS TO 5 OHMS WHICH ALSO BLEW A FUSE TO THE INJECTORS. MY INJECTORS ARE 1000CC SARDS THAT ARE LOW IMPEDANCE 1.5 OHMS.
NOW JUSTIN LETS ME KNOW THAT MY MOTOR SOUNDS FARKED AND BELIEVES THAT SOMEONE HAS FLOGGED IT ETC AS IT SOUNDS LIKE BEARINGS. AT THIS POINT MY WIFE IS WANTING ME TO HUNT DOWN AND KILL MY PANEL BEATERS BUT I KNEW I COULD TRUST THEM.
THIS IS WHERE THE SUICIDAL THOUGHTS CREEP IN AS THIS HAD COST ME OVER $500 AND NOW I WAS LOOKING AT A REBUILD.
I DRIVE ALL THE WAY UP TO CAPALABA AND HEAR THE MOTOR AND IT SOUNDS LIKE A FARKING DIESEL......
ANYWAY I GET IT TOWED TO MY MECHANIC DANIELS DJ SIVYER AT TIMMS COURT, WOODRIDGE AND HE DIAGNOSED THE PROBLEM BEFORE IT EVEN ARRIVED........
ANY IDEAS ????????????????????????
https://www.sau.com.au/forums/topic/273635-finally-solved-my-problem-can-you/
wrong fuel?
Chicken soup in your intake manifold?
Busted rivets in the floorpan?
Transmission mound not transmitting?
Central furfle mechanism not balanced?
Doves nesting in the i.c (corrosive dropping caused a leak)?
Doubling the clutch on downshift with a single plate clutch?
Fuel filter?
If it's none of those.....??
Man you must have felt some pain for a while, glad it worked out ok for you.
Happy days hey.
ANSWER WAS !!!!!!!!
From all the cranking from people trying to get it to run left a fair amount of fuel in the cylinders as it wasn't being burnt up. Then obviously they would think what next and let it sit.
Basically from the motor being cold the fuel would then run past my rings down past the piston and down the rods into the sump.
So basically my car decided to degrease itself. As a result it wasn't lubricating itself.
When we pulled out the dipstick there was almost an inch visible of fuel as obviously fuel and oil seperate.
When you touched the oil it was like water. I have since dropped the oil and put in some Valvoline XLD(Cuz its cheap) and a new filter and the motor has quieted down again.
I will now have to put some good oil back in it, flush the oil cooler and relocated filter assembly again to ensure that all the fuel and current oil gets the fu(k out of my engine and see how it goes. Im hoping as the car was barely run with this problem that there is very little if any damage to the bearings.
Anyway I never knew this could happen although I had heard of cars hydraulic a big end.
Now concentrating on getting her ready for powerplay. I hope it never happens to anyone else as it has been a week of hell.
Cheers
Bill
OH AND YEH.....MY NOS SYSTEM WAS OVERLOADING, I TOLD IT TO SHUT UP AND SLAMMED IT SHUT, THEN MY FLOOR PLAN DROPPED OUT MAKING SPARKS FLY EVERYWHERE.... NOW THE MAD SCIENTIST HAS TO TEAR THE BLOCK DOWN AND REPLACE THE PISTON RINGS THAT I JUST FRIED......
Yes I live a very sad life LOL
I had a similar experience with an LJ Torana (my first car)...
Leaking fuel pump (mechanical fuel pump, is lubrcated by the sump oil, driven via the cam shaft)
The difference with more story is the sump went down the head went up and a hole pile of flames said good night to that engine... :thumbsup:
Once you get a bit of heat in that engine all the fuel will evaporate out of the oil, but the mixtures may be a bit rich. Glad to hear it wasnt overly major, still alot of drama you dont want though.
lots of red herrings in the plot - if you go to the start where you dropped off the car at the panel beater and later after they had made lots of short start-ups (to move the car around or whatever ) and you return to find the car won't start but has good battery then what you could have/ should have done is floor the throttle and hit start, this formula is the first thing you should do whenever prolonged cranking gets no start - it eliminates any possibility of flooded engine being the reason for not firing - soon as the motor begins to run you lift off throttle of course! - the method is entirely safe, you won't blow up or over rev a motor that way
the logic is that when any f-inj cars are started lots of fuel is injected in first few seconds (compared to normal running ) and repeated unsuccessful short start-ups or non-starts will almost always flood the cylinders in quick time
in the older days with carbie systems you always would depress the throttle nowadays with f-inj systems you don't need to do that so many people don't even think about flooring the throttle in f-inj motors to clear flooding
With my Haltech E11V2 computer and average cold start map trust me I know to put the pedal down to get it started. The problem was that the back pump(External O44) was not priming/powering up. That was the initial symptom.
Also trying any interaction with the pedal had absolutely no effect at all as it didn't even make the littlest kick. That's when I knew something was seriously wrong.....
So when you go to start a car and it isn't getting fuel up front it wont start..............Hence that is why I requested the services of an auto electrician of which they could not locate any potential problems.....
So I don't see any red herrings in here...
I went with a logical process of elimination and the funny thing is she is now running but no-one knows why it stopped in the first place.
One possibility was that the panel beaters jumped the car causing it to spike the computer.......
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
