for sale r33 gtr vspec
body
full veil side body kit ,tinted windows,nismo rear spolier ,driving lights in front bar
interior
touch screen dvd player , trust gear knob , greddy boost controler , turbo timer , greddy water temp and boost guages in side pillar pod, greddy oil temp and oil pressure guages as well as the stock gtr guages has 97 000 km on clock
drive line
tein coil overs , new front and rear pads machined front rotors ,starcorp wheels 9.5 inch wide all round with bolt on spacers
brembo brakes as standard exceedy hypersensitve button clucth mated up to a aluminm flywheel with replaceable inserts
engine
engine is a r33 gtr vspec orami japenese bulit rb 26 twin turbo
has jap front pipe 3inch exhaust twin genuine n1 steel wheel turbos
twin pod filters with no air flow meters changed to map sensor ,large injectors ,fuel pressure reg with bradied lines
custom made front mount thicker then normal ,custom made alloy oil catch can , haltech full ecu , walbro largest intank fuel pump , vehicle puts out 332 kw on 18 psi currently set at 1 bar producing 300 kw at rear wheels with dyno sheets.
selling due to just brought a house .
regret full sale no tyre kickers
27 000 ono vehicle is a genuine gtr vpec rare in black gararged comes out twice a month if that .
https://www.sau.com.au/forums/topic/273647-for-sale-modifeid-r33-gtr-v-spec/
hey thanks i wish i did not have to sell it the n1 turbos are great they start to react very well above 16 psi the note of the steel wheels sounds awesome and they dont die off it just keeps pulling
it is a late 1995 mod and has all been complied green plate etc cheers josh
    • The more I think about it, the more I should probably go with a genuine Bride seat and rail set up. But damn the $$$ for a driver and passenger seat + rails!
    • From what I understand, stock internals should hold out for a while even if you run 500 at the crank, no? Especially if you don't run a modern turbo setup that reaches power and torque much earlier than the original twins. My engine isn't unopened either, it has N1 Pumps, head oil restrictor, new crank and cams, new piston rings, ARP head studs and Cometic headgasket along with 2860-5s. Considering everything is healthy this should run fine for a while I assume. Once my engine stops leaking shit everywhere, it'll be tuned to 370 crank first anyway, because I need to legalize the turbo setup. If I end up needing a new engine because my block actually has an issue, even though GTSboy was adamant that the whole porous block story is nonsense, before putting an engine in I'm probably gonna take care of the weakspots.
    • Hah, I have no issues with what you are doing whatsoever! You clearly know what you are getting yourself into. It's just funny reading things like this. "What's that noise?" "Oh, that's normal. That's just the engine not getting any oil. Nothing to worry about. It'll go away in a moment"
    • Yeah I'm keeping an eye on it and might take it out as a once off if this doesn't fully charge. I did some research that said it's normal in equalisation charging. Voltage I thought was 20+ (faulty battery in multimeter) but now its on 15.9v, the max it should go to is 16.2v as per the manual. I'll provide an update once hopefully it's actually fully charged and in float mode. Waiting for it to go to 16.2v and not higher and see what happens. What I suspect has happened is that even though it's not an old battery, I did leave the car turned off for almost 4 weeks at one point then left it off for another 2 weeks which might have erroded the battery and is taking a long time to do this equlisation charge.
