There are a few places where the clutch can be squeaky.
1: Pedal box pivot joint (common)
2: Clutch master cylinder thrust rod - a: at pedal connection (common). b: at ball and socket.
3: Slave cylinder thrust rod - a: at fork pivot point. b: at ball and socket.
4: Clutch throw out fork pivot.
5: Throw out bearing carrier.
Instead of using CRC/WD40, use a light film of grease instead.
This will sound odd, use olive oil to lube...Use some cotton wool or tissue ect soak in olive oil then sponge it on while moving the pedal.
The reason behind this is it will leave a nice thick film of lube on the parts and wont stink out your car like wd-40 ect.
I use olive oil on hinges in houses ect for the same reasons and it works better than anything else for low speed/load lube apps.
It's long lasting and should be ideal to do your pedal box.
It's a very old trick, I know it sounds odd but the proof is in the results.
Edited by madbung
It seems its much more louder outside, the wd40 helped a little to soften the sound but the squeaks are still there.
I might try this olive oil idea. will let you know how it goes.
i wouldnt recomment using grease around any rubber seals. We changed a clutch master cylinder on a car yesterday. The grease actually f#*ked up the master cylinder because it ate away the rubber seal
Plus, now your joint has that authentic mediterranian taste that can't be beat :P
  • 5 months later...
I had exactly what you described. Bought a new pedal box fixed it completely. The old one had been welded up in an attempt to fix the bending that often occurs on the stock unit. You can even buy a Nismo one which is much stronger.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
