Time for a big clean out! Stuff at low prices!
Pickup can be arranged from northern suburbs VIC or Melbourne CBD
Quantity is shown in brackets. i.e. (2) means i have 2.
Prices are per item, and exclude postage unless otherwise stated.
All items are used in good working order unless otherwise stated.
Offers by PM please
Pics coming soon!
:thumbsup:
SR20 Turbo Inlet Elbow (1) - $20
SR20 Coil Pack LoomsSR20 (5) - $20
SR20DET AirboxSR20 (1) - missing one clip, small round hole has been melted into it presumably for some kind of mod - $40
CA18DET water pump (1) very good condition - $20
CA18DET Idler Pulley (1) - Brand new - $100
CA18 Turbo Inlet Elbow - $20
CA18DET AFM -> Turbo induction pipes (2) - stock rubber pipe - $10
CA18 Wastegate actuator (1) - $20
CA18DET Tensioner Bearing (1) - Brand new - $90
S13 analogue climate control units (2) - one has sticky buttons but could be cleaned up - $20
S13 cooler intake crossover pipes (see pics when they're up) - plastic stock items for silvia and 180SX - $20
S13 Centre Aircon Vents (1) - Brand new in box - $90
[0b]R32 GTST M front bar [/b](1) in silver, intact with a few scrapes and dents (as pictured) - $20
R32/S13 Castor/Tension Rod (1) - stock - $20
R32 coolant overflow tank (1) - Fine apart from tiny (drip) leak in bottom, could be sealed without much hassle - $20
R32 power steering reservoir (1) - from R32 with HICAS. no leaks. fine other than wires from cap broken off but still have it with the plug (for level sensor) - $20
R32 GTST rotors (front pair) - both ~27mm - $40
RB20 TPS (1) - $40
RB20DE AFM -> Turbo induction pipe (1) - stock rubber pipe - $10
RB20 Turbo Inlet Elbow (1) - $20
RB20 S1 Coil Pack Loom (1) - half plugs cracked. good if you need to replace a cracked one or 2 on your own loom - $5
RB20 S2 Coil Pack Loom (1) - All good except for #1 connector missing. wiring is there though. - $20
RB20DET Exhaust heat shield (1) - $10
RB20DET motor with polished & embossed CAM gear cover - was complete when i bought it but have since pulled a few parts off it.- $250ono
So engine excludes the exhaust side, ps pump, alternator, A/C compressor, AAC, TPS, injectors & rail, coil packs).
RB25 Airbox Snorkel (1) - A rare find!! - $40
RB25 Crank (1) Had been straightened not long before the motor was pulled down - $100
RB25 block (1). Some damage to cylinder walls. Might be ok with a bore/hone? - $20
RB25 Stock oil cooler (1) - $15
RB25 Turbo oil out/drain pipe (1) - $15
RB25 Water pump - used but not for long before engine failure - $20
RB25 S1 Coil Pack Looms - (3) - $25
RB25 S2 Coil Pack Looms -(2) - $25
RB25 wastegate actuator (1)- $20
RB25 AFM -> Turbo induction pipes (3) - stock rubber pipes, unsure exactly which model they're come from (see pics when they're up) - $10
R33 GTST rotors (rear pair) - both ~18mm - $40
RB coilpacks (6). From an RB25. Were replaced with spitfires due to miss under high boost. - $20
RB26 Rods (6) + forged RB25 pistons (6). Pistons are damaged - unsure if salvageable? - $250 the lot
RB26 stock fuel rail & reg (1) - $70
Z32 Complete airboxes (2) - $50 each
Aftermarket Gearknob (1) Red with fake CF - $5
External fuel pump brackets (3) - aftermarket and brand new - $10
  • 4 months later...
  • 7 months later...
i'll take the water pump for the rb25 if its in good nik..when can i pick it up? lemme know...gimme me a call or txt. 0411795674 cheers
Edited by ZaLaZaNe
    • https://www.efisolutions.com.au/coolant-temperature-sensor-bosch-180sx-s14-s15-r33?gad_source=1&gclid=CjwKCAjwzMi_BhACEiwAX4YZUHsCQhbiDT_NC3q5wD9jrzH6Dts9eGSr19NXSDw7x9WVm1sH7G3S4hoCwaUQAvD_BwE this is the one i replaced today
    • I have replaced the larger coolant temp sensor, i do see a smaller one next to it (looks to be just 1 pin) but i assume that is just for the dash? or should i replace that aswell?
    • Check coolant temp sensor ~ symptoms fit the hard hot start/cold start OK scenario --- if sensor goes open circuit, ECU thinks engine is cold and enriches mixture ....works when engine cold, but floods them with rich mixture when hot (Hyundi MAP engines are a bit infamous for this)...
    • OK, starter changed for a spare without much trouble. Neil had kindly left space to get to the top starter motor bolt from above with a long spanner which makes the whole deal much easier, and everything else was neat and easy to get at from underneath. Once the starter was changed everything was good, unplugged the CAS and turned the motor on the starter to make sure everything was free and happy. Onto properly priming the oil and first start. I'd picked up one of these oil prime kit from Boost doc a while back and this was my first time using it.  https://boostdoc.com.au/products/engine-oil-prime-kit?_pos=1&_sid=28c628a65&_ss=r While I'd organised all the fittings to hook it up to my GTR (sump plug to -6 feed and -4 T to tap it in and retain the oil pressure gauge, neither suited on this car as the oil pressure needs to T into 1/8 NPT not -4 and the Aeropro sump has some massive drainplug not that factory whatever it is. So, waiting for a couple of fittings, then I'll prime it and do first start, hopefully next weekend. Other than that going well, there is very little stopping a final alignment, tune then shakedown day
    • Also to mention, i just tested the CAS, seems to be working fine, can hear the pulses inbetween 0 and 180 degrees, another mention aswell, when i let the car sit for about a hour today, i went to start it and it almost fired on first crank, then just completely struggled. Could it possibly be blocked injectors?, maybe allowing a little bit of fuel to seep past allowing it it almost start first crank?
