Time for a big clean out! Stuff at low prices!
Pickup can be arranged from northern suburbs VIC or Melbourne CBD
Quantity is shown in brackets. i.e. (2) means i have 2.
Prices are per item, and exclude postage unless otherwise stated.
All items are used in good working order unless otherwise stated.
Offers by PM please
Pics coming soon!
:thumbsup:
SR20 Turbo Inlet Elbow (1) - $20
SR20 Coil Pack LoomsSR20 (5) - $20
SR20DET AirboxSR20 (1) - missing one clip, small round hole has been melted into it presumably for some kind of mod - $40
CA18DET water pump (1) very good condition - $20
CA18DET Idler Pulley (1) - Brand new - $100
CA18 Turbo Inlet Elbow - $20
CA18DET AFM -> Turbo induction pipes (2) - stock rubber pipe - $10
CA18 Wastegate actuator (1) - $20
CA18DET Tensioner Bearing (1) - Brand new - $90
S13 analogue climate control units (2) - one has sticky buttons but could be cleaned up - $20
S13 cooler intake crossover pipes (see pics when they're up) - plastic stock items for silvia and 180SX - $20
S13 Centre Aircon Vents (1) - Brand new in box - $90
[0b]R32 GTST M front bar [/b](1) in silver, intact with a few scrapes and dents (as pictured) - $20
R32/S13 Castor/Tension Rod (1) - stock - $20
R32 coolant overflow tank (1) - Fine apart from tiny (drip) leak in bottom, could be sealed without much hassle - $20
R32 power steering reservoir (1) - from R32 with HICAS. no leaks. fine other than wires from cap broken off but still have it with the plug (for level sensor) - $20
R32 GTST rotors (front pair) - both ~27mm - $40
RB20 TPS (1) - $40
RB20DE AFM -> Turbo induction pipe (1) - stock rubber pipe - $10
RB20 Turbo Inlet Elbow (1) - $20
RB20 S1 Coil Pack Loom (1) - half plugs cracked. good if you need to replace a cracked one or 2 on your own loom - $5
RB20 S2 Coil Pack Loom (1) - All good except for #1 connector missing. wiring is there though. - $20
RB20DET Exhaust heat shield (1) - $10
RB20DET motor with polished & embossed CAM gear cover - was complete when i bought it but have since pulled a few parts off it.- $250ono
So engine excludes the exhaust side, ps pump, alternator, A/C compressor, AAC, TPS, injectors & rail, coil packs).
RB25 Airbox Snorkel (1) - A rare find!! - $40
RB25 Crank (1) Had been straightened not long before the motor was pulled down - $100
RB25 block (1). Some damage to cylinder walls. Might be ok with a bore/hone? - $20
RB25 Stock oil cooler (1) - $15
RB25 Turbo oil out/drain pipe (1) - $15
RB25 Water pump - used but not for long before engine failure - $20
RB25 S1 Coil Pack Looms - (3) - $25
RB25 S2 Coil Pack Looms -(2) - $25
RB25 wastegate actuator (1)- $20
RB25 AFM -> Turbo induction pipes (3) - stock rubber pipes, unsure exactly which model they're come from (see pics when they're up) - $10
R33 GTST rotors (rear pair) - both ~18mm - $40
RB coilpacks (6). From an RB25. Were replaced with spitfires due to miss under high boost. - $20
RB26 Rods (6) + forged RB25 pistons (6). Pistons are damaged - unsure if salvageable? - $250 the lot
RB26 stock fuel rail & reg (1) - $70
Z32 Complete airboxes (2) - $50 each
Aftermarket Gearknob (1) Red with fake CF - $5
External fuel pump brackets (3) - aftermarket and brand new - $10
  • 4 months later...
  • 7 months later...
i'll take the water pump for the rb25 if its in good nik..when can i pick it up? lemme know...gimme me a call or txt. 0411795674 cheers
Edited by ZaLaZaNe
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
