its a damn sexy but expensive factory option nismo oil cooler kit.
i dont know if you can get them anymore? i remember for example - seeing them advertised in a HPI magazine a few years ago and the price was around $5500 supplied (full package - vents, piping, tubes and cooler - etc), but not installed or painted. i probably still have the mag somewhere, i might be able to scan the ad if it would help you.
i've got one on my car and apart from mine, i've only seen one other GTR here in australia with the kit (well, that one only had the vents.. the cooler got flogged on the boat on the way over). they are a bit more common with the UK delivered GTR's, but i read somewhere that the ratio is still something rediculous like 1 in every 100 has it.
i think the extra vents make the car look alot more agressive. i've attached a more few pics for you. :thumbsup:
Edited by KR4-GTR
Thanks KR4
- I am keen to see what I can find.
- Are we sure it is a Nismo product?
- Any part numbers or identifiers on the parts that would help?
And nice car by the way - Could be a brother for mine (KR4 S3 Vspec) apart from that wicked oil cooler setup that you have :thumbsup:
Edited by Red Back
Thanks KR4
And nice car by the way - Could be a brother for mine (KR4 S3 Vspec) apart from that wicked oil cooler setup that you have :(
hey mate,
had a look today for you, cant find part numbers stamped sorry!
if you dont have any luck finding the kit and really want it, just give me a yell - i'd probably just sell the cooler and swap bumpers with you.
i love the stock look :)
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
