Got a few things need to get rid of as need extra cash for a holiday. Need it gone asap.
First off we have Fuji FinePix S9500
Basically brand new, only used it once at the EasterNats and been sitting on the table ever since. Got a 256mb and a 512mb memory stick to go with. Comes with everything included in the box, installation software, cables, manuals.
http://www.cnet.com.au/fujifilm-finepix-s9500-240056325.htm
http://www.fujifilm.com.au/products/item.a...id=1&pid=18
Also comes with 2 sets of rechargeable batteries (8 Duracell AA batteries).
They still retail about $600, asking $400
Also got 2 channel 250watt Sony XPlode Amp, brand new, never used, only missing box.$120
Sony 4 gauge amp wiring kit, brand new.$50
Willing to sell them together for $150
12" Pioneer sub in a Sony box. $120
Will sell the sub in box, amp and wiring kit for $250
5pce Mechanics Air Tool Kit
Only used the air drill once, everything else untouched
Contains:
1/4" Air Die Grinder
150mm Air Hammer
4" Angle Grinder
3/8" Air Ratchet
3/8" Air Drill
1/2" Impact Wrench
Plus I'll throw in 20m air hose with all fitting needed $150
5L Monza Red pain, 10L Subframe Black, 5L Primer Filler and about 20L of Premium Thinners.$200
Located in Melbourne, prefer pickup, but postage can be arranged
Contact on 0410518747, pm here, or [email protected]
Thanks guys
Jovi
https://www.sau.com.au/forums/topic/273683-fs-various-bits-and-pieces/
  • 2 months later...
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
