Up for sale is my 95 vr commodore. I have put in an rb25 and manualised auto. at the moment the car is almost complete it just needs to be wired up (can organise) and registered. I have recently got a new job and have no time to finish the car. Having said that if i dont get around what im looking for i will finish it off and be asking more. some of the mods are:
RB25 80000kms
r33 auto box with mv autos manualised shift kits
Custom engine mounts
custom gearbox mounts
2 piece tailshaft
r33 skyline fuel pump
malpassi 1.6:1 fuel reg
stainless top mount exhaust manifold
38mm external wastegate
t04e turbo
3.5" turbo back exhaust
front mount intercooler
custom piping
BOV
lowered king springs
KYB shocks
calais wheels
cd player
jvc speakers.
Car is in fairly good condition and with a little bit of money to finish it (probably $800 + rego) it will be a quick street sleeper with over 300rwhp and run high 12's.
Asking $7000 but price is negotiable.
sorry bout the pics I will take some better ones when i am next with the car.
Note: In these photo's cooler piping and hoses and exhaust ect arent hooked up but new photos will show it more recently but you get the idea.
If you are interested please call or txt me on 0402522053 or email me on [email protected]
https://www.sau.com.au/forums/topic/273688-holden-vr-commodore-turbo/
that is an rb20 mate...............
or a r32 rb25 DE................
what computer u running mate?
pelase change your topic to say RB25DE+T or rb20det......
cam you beat me to it.
definatly either a rb20det o a rb25de+t
also has the rb20det coolant system coming from the water pump to the radiator.
could be a late model rb20 or has the rb25 timing belt cover cause it dont have rb20 written in it.
also has the rb20 power steering pump.
is that an ebay topmount setup with screamer???
plz define and change you topic. its misleading.
Edited by sneaky1
correct. r32 rb25de+t. not an ebay kit but could be same turbo as they sell on ebay not sure. Is running the rb20 ecu. PUt one of these engines in a silvia but with a standard rb25 turbo and it pulled really well right up to the 8000 or 8200 rev limiter with also a heap of low down pickup from the higher compression. Only downside is just cant run as high boost as a factory "det".
those motors do have lots of torque as i had one in my old 32.
think the limiter is a bit high bro but nothing that wouldnt be adjusted when its tuned.
should go well. just not sure on the whole commy bit.
haha mate im still not sure bout the commodore bit. not really into them myself but thought id try aiming at a differnet market than the normal rb silvias and plus it adds to the sleeper theme.. the ecu is rb20 ecu because its pretty much rb20 head on rb25 bottom. pretty sure their standard limiter is at 8000 isnt it? either way will be a quick car when finished and hopefully break into the 12 second bracket down the quarter.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
